Fired a couple off today and all's good.
SE plate removed and new plate fitted:
Installed:
Hopefully the shaft to ball length meets your approval 😁
So I tested with a LS-32 (individual microswitches with terminals) and a LS-32-01 (microswitches soldered to a PCB + JST NH connector). Both fit fine. With the LS-32 a couple of the microswitches get in the way of the mounting studs in the CP and with the LS-32-01 the PCB gets in the way all the way around but you can get nuts on and then use a 7mm spanner to tighten.
Thinking of doing another version where you can either mount the plate-less LS-32 using the blue holes directly (as above) or if you wanted to use a LS-32 with a SE plate you then could fit that with M4 CSK screws to the adapter plate:
The 'blue hole' method requires less hardware, doesn't need an SE plate and gives you max extension but is a little trickier to install...
The 'red hole' method requires more hardware & a SE plate, it will reduce the max standout by 1.6mm but will be easier to install into the cab.
I know you may only need the blue hole version but I'll share both files online in case they are useful to anyone else.
Let me know which version you want. I'll test print a pair of the new version tomorrow and offer up the other set that you don't want to someone else.
Just PM me your address and I'll get them sent, should be able to send them as a letter as they'll be under 5mm. Don't worry about £££, pay the favour forward to someone else if you want to
