Midway transformer
sukhbir
46 (100%)
1,631CR
Hi,
I have this midway transformer and I want to use it to power up a pacman board to check if the ac to dc components function in normal operation.
Not sure if I can put in 240v ac ,there's 115v and 125v on the secondary?1000019704.jpg1000019705.jpg
philmurr
46 (100%)
2,350CR
No don't do that! It's not designed for UK voltage. Also the "60Hz" is a clue
You connect mains in from the brown/white (thermally fused) connection to the relevant other terminal (105V, 115V or 125V) depending on local mains voltage
