Solved Missile command - crashing - ideas? When high score entered
Sbdesign
SEGA collector
1,658CR
Hi,
Just had mc pcb fixed.
I soak tested which was totally fine
But now I realised that if I get a high score and put In Initials It instantly crashes after it.
Anyone know what could cause this? Or likely?
Or if a high score kit would eliminate it?
Appreciated thanks.
philmurr
46 (100%)
2,328CR
If it crashes at the same point then most likely a ROM issue.
As the Braze kit has its own ROM it may stop the game from crashing, and will also save the high scores.
Sbdesign
SEGA collector
1,658CR
I’ll give it a go
I have a clean board that needs repair so if I knew which rom it could be I could try swapping it out
UPDATE: put braze kit and ok!
