Monitor issue
Yakama
234CR
Firstly does anyone know what model this chassis is?
When it arrived it was dead, a few cracked solder joints sorted and now it starts up but the image is kinda washed out and shadowy, it’s also sometimes distorted somewhat. I will recap it and hopefully that sorts it but if anyone has any other ideas?
It was very clean and doesn’t look like it’s been touched before. I don’t even think it has been taken off the tube before
NLjevader
36CR
It looks like a Wells Gardner k7000 chassis for a 25" tube ( 25K7000 ) 😇
Yakama
234CR
Also should this auto degauss as it doesn’t seem to and I can’t find a button anywhere. There was one in the machine with the coin counter but it doesn’t seem to do anything when pressed
3,258CR
Try turning down the blue cutoff pot or the blue gain pot on the neckboard. They don't have an K7000 chassis don't have a button for degauss (I don't remember ever seeing one anyway). If it's not auto degaussing you need to check that part of the chassis over.
Yakama
234CR
Thanks ok will have a look at that then
3,258CR
Hmm, it might be a leaky transistor on the neckboard or on the chassis then in the blue circuit. Are either of the pots cracked? Also, just noticed the start of the sentence I typed above about the degauss doesn't quite make sense! :LOL:
Yakama
234CR
So after giving all the pots a good clean with ipa the monitor now looks much better. I’m waiting on caps to recap it then it needs a bit of setup. I can’t get it to look sharp with the focus adjustment yet but it’s such a massive machine im having to adjust round the back then check round the front and I’m finding it difficult to set that way. But overall it’s looking much better and is now at least playable.
Next is to sort the cracked wood, replace the worn out buttons and then look at getting a new control panel overlay made up
Yakama
234CR
Oh and the thermistor for the degauss has a big crack in it so think that’s why that isn’t working. A new one has been ordered so hopefully when that arrives I can fix that too
3,258CR
Can you position a mirror so you can see the front of the screen whilst you're round the back of the cab? You may find the focus pot is going bad, that lopt appears to be an original as fitted at the factory. They often get hairline cracks in the case due to age, and sometimes you'll get one going right through the focus pot area which nearly always affects the way the pot works. If you can't get the focus set or it drifts once set you'll need a new lopt.
Yakama
234CR
Yeah maybe I will need to get a mirror and try. Waiting on the cap kit to arrive so haven’t touched the chassis again other than trying to fix the degauss issue. New thermistor arrived but hasn’t fixed it, can’t see anything else testing wrong so have bypassed just now with an external degauss circuit and that’s fixed the issue.
Will recap it and try getting it looking a bit better and if I still can’t focus it will get a new lopt
gunblade
22 (100%)
8,863CR
for the degauss issue check the 15r resistor at R104, they are a common fail
the focus issue could be the balance of contrast, brightness and screen volts adjustments, crt socket can also produce poor focus and of course flyback focus pot corroded or even tube weak
Yakama
234CR
Thanks I will check this. I’ve just had a look and there is a big crack right through the lopt where the focus pot is so I’m guessing that’s the issue
