Hello,
Here I have another tough one. After getting rid of some stuck blue horizontal lines (bad LS273 on S9), I can't find any other fault. All GFX roms are fine. 3 of the 4 CPU roms dosen't match any romset. I guess this is because there is no PAL at J2 so must be some hacked roms. I did put an diagnostics ROM in and it shows all rams are fine.
Can anybody do some measurements on theyrs?
OB1-OB4 outputs on G10 (LS157) are LOW. The IC is good and if out of socket, everythis is floating, so no stuck inputs. There is acitvity when sprites should be displayd.
There are no pull-ups on the PROMS (E10 and J10) but they are tri-state so it shouldn't matter there is activity on all the outputs.
Any help is appreciated.
Thanks.
https://www.arcade-museum.com/manuals-videogames/M/MrDo.pdf
Got it... it was the two 2148 SRAMs at F8 and G8. I tought that I could get away using 2114 instead. Pulled 2 from other working PCB and it restored all the sprites... Good one.
OB
Thanks.
