Mtc 900 width adjustment
stevebm1
38 (100%)
1,228CR
Hi,I have just tube swapped a hantarex mtc 900,the old tube was 19”,the new one is 21”,yoke readings were fine and the chassis runs with a nice image,I have tried adjusting the width coil and pots,but the image is still too wide,Im sure I read somewhere years ago that you can change cap 69 to a different value to solve this issue,is this correct?,and if so what new value cap do I need?
Thanks in advance
stevebm1
38 (100%)
1,228CR
Well had a chance to fiddle with this earlier adjusting down to 120,v and things were 95% better,so I went a bit lower at 115v and it’s now a perfect fit to the screen.
The question is,am I ok to leave it running on 115v or should I change cap 69 instead?
