Multi game pcb for sega naomi universal jvs
Markitanis
70CR
Hu guys.
ive got a sega naomi universal Jvs and want to know if there is a plug and play solution like a pandoras box or even a small pc etc that i can just plug in and play. Links appreciated
thanks
Crazy_1201
66CR
Depends on the monitor in the naomi- they usually come with a 31khz monitor which is 480p or 640x480 resolution at 60Hz, you need to output the correct resolution from your PC. The vga cable from the machine should connect directly to the pc.
For the controls look into jvs pac.
Also see this link:
