Great. Glad it's working well for you.My PSA of the day, the CV1000 core runs GREAT on the Mister Multisystem JAMMA!
On the normal Mister I think it’s F12. Hopefully you can plug one of those Super tiny blue tooth keyboards as they are super handy for mister.love it so far and been testing it in and out of my jamma machine. One thing I’m having to do though to change game is to turn the machine off and on, which is ok while I’ve got it opened for testing but not ideal.
how do I get back to the OSD menu or reset? Can I map buttons somehow I.e. in groovymame ive got P1+P2 mapped so it takes me back to the menu when they’re pressed together.
Thanks - got the keyboard method and have one of those, but is there no way to do it without any external control input i.e. just from buttons on the machine? I don't mind if I have to add another one. just can't see how to do it.On the normal Mister I think it’s F12. Hopefully you can plug one of those Super tiny blue tooth keyboards as they are super handy for mister.
Yes would be great if could do it from control panel. Will keep an eye on the post. ThanksThanks - got the keyboard method and have one of those, but is there no way to do it without any external control input i.e. just from buttons on the machine? I don't mind if I have to add another one. just can't see how to do it.
You can do this from the sub menu (back button) look for Define Joystick Buttons, and go through the setup and eventually you'll get to the menu button you can define a button or a pair of buttons for Menu. you'll want to plug in a keyboard for the inital set-up to skip all the mouse and analogue sticks stufflove it so far and been testing it in and out of my jamma machine. One thing I’m having to do though to change game is to turn the machine off and on, which is ok while I’ve got it opened for testing but not ideal.
What’s the line of code that needs changing ? Mine shouldMy multisystem arcade turned up today. I took the sd card out of my old mister, changed the line of code and BOOM (not literally 😂) it worked!! Only had a quick go but seems so good! Super happy with it. Thank you Heber 👾
Hey ThanksThe user guide is not as long as it looks. Very well written. The code is for the controls.
Thanks for highlighting this. The Player bindings are really useful to do in the Mister.ini file as they lock Player 1,2,3 & 4 to the same outputs for every core.The user guide is not as long as it looks. Very well written. The code is for the controls.
We are looking at this. I hope we can have a few simple adaptors to the correct wiring scheme for system types.Does anyone know if any adaptors are, or will be made available to allow the Multisystem 2 to be plugged into a dedicated cabinet such as Outrun? It could be great to play the Outrun Arcade core in a proper cabinet + others like Powerdrift etc, which I see are coming out, or at least they will be soon.
if it is like my 4-slot it is not wired to JAMMA. From memory it is sound thing to do with the way the sound signal is wired.Good afternoon, Just after some advice. I have a mister multisystem jamma on its way to me, which I am very excited about! I just wanted to check I am ready to plug it in when it arrives? I have checked my Jamma harness connector and some of the wires look like they are in different places to what a standard jamma pin layout is (see image). View attachment 64096Also a couple of the voltages are a little bit off (see image) I assume they are doing the correct things because at the moment I have a Neo geo one slot board plugged in and all working fine. The cabinet is a Lordsvale neo geo cab and I am pretty sure the cabs wiring is for a multi slot mvs board. Hope this all makes sense as I am still learning. Thanks
All the motion DLX cabinets seem to do things differently, which doesn't help. Limit switches, potentiometers, different drive PCBs etc, so you might end up needing a different interface PCB for Powerdrift, Outrun, Galaxy Force....Does anyone know if any adaptors are, or will be made available to allow the Multisystem 2 to be plugged into a dedicated cabinet such as Outrun? It could be great to play the Outrun Arcade core in a proper cabinet + others like Powerdrift etc, which I see are coming out, or at least they will be soon.
