MVS Strikers 1945 Plus
MarsellusW
8CR
Well, i have a mvs cartridge that has doen it only once in my machine and not in the other machine of my friend.
It starts up and you can start the game but there are no sprites of the planes or the enemies. The board looks clean and all the contact are still connected. (The soldering is in tact with all the chips.) Anyone have an idea what the problem can be?
I will post some pics also.
Mc-Q
1,450CR
interesting.
i would find out whats different.
check the 5v level in your machine and your friends.
maybe a chip on the cartridge prefers higher or lower voltage.
FMRad10
119CR
I've had various sprite issues with MVS stuff all through my collection. I assume you've cleaned the contacts thoroughly with IPA/Contact cleaner and even a rubber after that just to buff them up? the amount of carts I've bought that have had issues and have been fine after a proper clean has surprised me.
failing that and the issue is missing sprites, next I'd check the C ROMS (C1-C8, https://wiki.neogeodev.org/index.php?title=C_ROM ). these house all the sprite data. I bought a Shock Troopers cart "untested" that ended up looking like it had never been played. had some missing sprites on the title screen. everything looked great on the board around the CROMs until I spotted what looked like the tinniest bit of corrosion on a trace coming off a pin on the back of the board. could barely see it but I had nothing else to go on at the time so done a continuity test and it didn't beep so ran a wire from that pin to the pin on the next chip it was going to and HEY PRESTO! all fixed. don't discount any minor imperfection when dealing with these. Even going so far as reflowing the solder on all the pins on the CROMS just to be sure there's no dry solder joints as these carts are starting to get on a bit and it could be an issue.
If it's happened only once I'd not worry too much about it. if it happens every time in your machine and not your friends. try cleaning the contacts in your machine as well. Then as Mc-Q said, you might need to start looking at 5v level or the possibility of a bad chip but I don't think that's the case if it's good elsewhere.
MarsellusW
8CR
Some photos of the boards. I cant seem to find anything weird.
Also, it worked once in my cab. After that not anymore...
FMRad10
119CR
Only thing I have is on the PROG board. check continuity between the 2 points I've highlighted. Not sure if it's just the lighting or not but the trace I've circled looks different to all the others. could be corrosion.
I'd also double check my tracing is right. I'm about 99% sure it's correct.
