My final Donkey Kong resto'
G
Guests
Guest
Hey Tony, thank you sir.
P38 is all I've ever used and will ever use. It can shrink slightly but I'm using a finishing stopper this time which is a very fine premixed filler/putty in a tube that doesn't shrink and also doesn't leave those tiny holes that fillers do.
P38
finishingstopper
I find P38 very easy to shape to get perfect edges and sanding is a breeze (being called easy sand holds true) A chippy mate recommended it, it's all he has ever used and been a carpenter for over 40 years.
niknak
Raffles the gentleman thug
172CR
This is great! looking forward to more
Nintendo Arcade
AL’s Arcade
756CR
Good to see the base is solid Al
I have to say I've never had a bad base on any of mine except sheriff which is completely missing,but because of the pure weight of it I've left the four wheels on for now but the plan is to build a new one for it.
Great up date
G
Guests
Guest
Managed to escape to the Garage for a couple of hours this afty.
All a bit of a yawn to be honest, all about filling and feathering in.
Was in Town this morning so did some shopping
Then sanded all of what I'd done Monday
More filler (yawnz!)
More sanding (yawnz!)
Mr Maclean
Base
Base sanded (not quite finished) minor repair which wasn't necessary. I really must take those damned wheels off!
Back of cab
The first side is virtually to a point where it's ready to prime so filled one final time with the finishing putty. Will then feather it in hopefully in the morning then sort out the other side/front coin door panel and finish the back.
TBC
G
Guests
Guest
It's in the link under Tony's post up there ^ Nad
Sarj, Mr Lilley is first in line but you're a solid no 2
Vamino
Insert coin(s)
2,670CR
Really nice seeing this unfold, thanks for sharing
I don't care what anyone else says, there's not much that beats a nice restoration.
G
Guests
Guest
I forgot to say, I ordered the paint & primer today. That should be here tomorrow.
G
Guests
Guest
Thanks you guys, I forgot how much mess these buggers make!
Rich, I'm happy with the results I get from rattle cans. Galaxian to do yet, limited spraying which is cool!
No point using staples as the panels are glued and screwed anyhow, overkill!
PAC-MAN2015-08-20 21:09:27
RSwanson
205CR
P38 is great stuff, unless you do the work in your conservatory, in which case it will stink out your house until you move.
How does this buyers "line" work? If I "dispose" of the others "Ray Donovan" style, does that put me at the top of the list?
strykr
1,348CR
P38
finishingstopper
Finishing stopper eh? cheeky!
i wondered how to avoid those little p38 holes they are annoying!
nice.
