Problem Naomi rca buzzing
Sbdesign
SEGA collector
16 (100%)
1,671CR
I have a Naomi with real bad buzzing from rca’s
Sound also works
Not tested a different Naomi in machine yet
Tried diff cable
Note: fan is very noisy
Anyone had a similar issue and resolved it.
jerryspaghetti
32 (100%)
1,792CR
Mobo fans are often noisy and can be cleaned or swapped out with a quiet one easily.
The buzzing from the audio could be anything on the amp. Check caps are good and solder joints. If you need a replacement for parts I have one knocking around.
Sbdesign
SEGA collector
16 (100%)
1,671CR
Yes but only when plugged into Naomi rca
I need to try a external source to the amp
But funny feeling it’s a lot of static from Naomi out
Hopefully I’m wrong.
7,319CR
Or plug Naomi’s phones into another amp.
You could try putting a multi meter on the rca metal outer and see if you got any voltage on it ?
Then check for bad solder joints
Bad caps
