Need help for Hammerin' Harry M84-A with graphic glitches
vsl
51CR
I trying to fix Hammerin' Harry M84-A-C with Graphic glitches.
Test give bad ram NG 9 .
Where is location this chip.
Thank you :)
Funhouse71
982CR
vsl
51CR
i check these IC11, IC12, IC13, IC14 on all 4 chips the address bus is stuck to low and tracked her down to this skinned custom chip 64pin.
Ace`
PlanB contributor #1
35 (100%)
3,742CR
Did you lift the pin at the custom to make sure it's not one of the rams pulling it low? It most likely is the custom though I've seen a few bad GA22 customs already. :cry:
vsl
51CR
Тhe case is solved...
unfortunately it turned out to be true that the custom chip is damaged.
After removing rams and testing them, they all work.
I removed and customized the chip ... after elementary measurements between legs his no gave resistance anywhere .
Can such a chip (i think is Nanao KNA70H015(11) ) be found anywhere?
Thank you !
