Nintendo Space Firebird Side Art & Upright CAB Build.
conan
225CR
It seems to be widely agreed on (in the USA) that the closest red laminate available is Nevamar, Liberty Red S-1027 Gloss. I have a sample and have now started figuring out what material thickness to use for the cabs side panels.
The layup sandwich is mainly driven by the 'true flat' T-Molding thats available and it seesm to be Mikes Arcade has the correct profile thats 9/16th wide or 14.2875mm.
The Nevamar measures in at 1.05mm so its looking like I will be using a 12mm ply (readily abailable) for the side panel as the inside surfaces near the controls and screen looks to have a smooth black vinyl applied to them too, which will need calculating in.
If I go with a 12mm ply core then that leaves me nearly 1mm of adhesive (blue in diagram) for the laminate and .5mm for the interior vinyl. Worst case I can fold the Vinyl over the edge and have a slight reveal if I need more adhesive. Like I did on my DL refurb. I definately do not want the laminate over hanging though. The T Molding slot will be offset and I can easily calculate that from the CAD.
Dl side panel with folded over Vinyl.
conan
225CR
Todays news is that I have the artwork for the metal serial plate finished and a company to output them on stainless steel with holes cut and the black over printed.
Ill be stamping the serials and other data with some punches. I have to order a quantity so if anyone wants any let me know. I can stamp them up with whatever info you want when they are ready. Ill have to figure out a price though.
I also have the artwork finished for the Switch Plate stickers too.
These are accuarte copies of originals.
conan
225CR
I purchased a donor cocktail machine and have started gutting it for parts. Its not easy finding an original 2 way joystick so I have removed one from the donor and set about modifying it.
Got lots of other usefull parts from it too, like a oin counter, original speaker and service switch.
I stripped the joystick and gave it a good clean. Although I think it will fit the control panel I machined off the two extra side tabs so it mounts with plenty of clearance.
Re assembled and I now have an original 2 way joystick, not exactly the sme as the upright original mechanism but still has sprung centering the correct diameter ball and a great mechanical feel. Plus I have another spare.
I also got x2 of the blue cocktail buttons from the donor, that are super rare and metal mounts and original button switches.
Ohh and a £1 coin and a US quarter....
Ill have to refurb the buttons but ill get to that at the time of install.
conan
225CR
Great work, I have these sticks and most of the other bits you have gotten from that table, did it come with the game boards?
Yes and they are off to an awesome repair guy. I managed to repair a bootleg board but Im done trying to do more, it was a nightmare.
Ronnie Dent
1,205CR
Yes they are tricky to repair! Is it a repairer on here? If it's a game your planning to keep having working spares is needed! I think I have around 10 but only 3 working sets
