Op Raid: March 2014
smarty
Ready Player One
1,290CR
Alpha1 said:
That looks like an Atari built Hang On..
I'm not sure if sarcasam was intended
but yes its had an Atari ARIII installed as some point, a standard switcher and a birds nest of cables.
Surely this wouldn't have come out the factory like that?
Milky
987CR
It looks like a lot of "just keep it going" work has happened over the years. As it stands, there's far too much electricity in there for me to feel comfortable with just poking around right now. Need to unpick this one carefully...
Milky
987CR
philmurr said:
Don't be a wuss, just switch it on like Smarty does with his new games and I'm sure it will be fine...
Sure! Just look west out of your window and watch for a mushroom cloud
5,392CR
Atari built some Sega machines (and Namco and Exidy) at the Atari Ireland factory.
That's why some Sega Outruns have the Atari audio amp etc. I would imagine the plate on this machine says 'Sega UK' or something similar.
The ARIII, the very familiar Atari plastic shroud covering the power switch, the wooden pull back handle on the back of the cab and the power brick are all Atari.
4,542CR
can always tell by the audio amp in the cabs, if it's sega amps then it's sega built, atari amp/reg board it was built at Atari
Unless the wiring has been hacked and you would tell then
Danscu
252CR
smarty said:
deano76 said:
The shape of your cab looks identical to my Scud Race upright ! Only the pedals and dash look different
I think there was a Daytona or maybe a Scud cab on ebay recently that looked like this shape cab too.
The switcher in this cab is made by Deith Leisure along with the manual, The picture of the gear shift in one diagram is the same as Sega cabs not like this Midway game.
I think someone mentioned the Outrunners from this raid was a Deith Leisur cab as well, I take it there were a distributor for Sega then?
I've got the same Cruisin World cab which has been mamed and has that Sega sticker on it too - interesting about Scud Race as that is on my list to get running in there assuming the PC is powerful enough:)
smarty
Ready Player One
1,290CR
Oll, Now you've said it I can see all the other Atari parts... Milky have you turned it on yet then?
It is defo the same cab profile, see below. I need one of those seats, anyone see one on there raid? It will make the cab better to play as the pedals are quite high sitting on the plinth when playing it as an 'Upright'.
Milky
987CR
You guys just won't be happy until I blow myself up, will you?
I will fire it up tomorrow when hopefully the air won't be so damp.Milky2014-05-01 18:22:32
devtty0
196CR
The Time Crisis got delivered by Martin last week:
Massive thanks to Alpha1 and everyone involved for making the raid happen
its a big fekker mind : its a good job its in the basement, as I had to saw a good chunk off the door-frame to get it in there!
thanks again, hopefully I can help out at some point in the future to pay back the effort.
devtty0
196CR
yeah, it is: the artwork is missing on the other side, but that side is minty-fresh .. hence the doorframe being sacrificed to prevent it scraping on the way in!
it actually fell on me when we were pulling up the path as well - thought I was a gonner!
Danscu
252CR
At last I've got a couple of pics of the Lordsvale from the raid, thanks again Alpha1 for organising it!
Cab is in great condition, has a lovely monitor and CP. The 6 slot had a fault but I had a spare 4 slot so no problem there, and I've just swapped the buttons out and made a small repair to the wood under the CP where a small section was gauged out.
