Operation Wolf Story Restoration
5,033CR
The next part wasn't easy, the front left corner had been bust off at some point and been repaired, didn't notice when I bought it, so another surprise to sort
They couldn't even get it straight and I have no idea why the holes
wasn't sure how I could sort this other than a better bit of wood, good thing when you've had a few machines, always have some wood to use, even better when it's got the vinyl that just about matches, annoying when you probably had some exact stuff but throw it away because of space issues
If I'd make any mistakes with this, I'd end up cutting more and more off the original side, luckily it went well, cut it bigger to start and then trim it down till it fits perfect, it's getting the right angle though
Fix it in place with wood dowels, once side is on again it will have more wood dowels through the inside but needs to be strong
Getting there
Corner done, then still slot to cut and holes on inside for dowels
Doesn't blend in too bad, not much else can be done unless you recover all the wood but I'm happy with it. I do most of my work on the patio area, like lately were having all this rain, it means I can't get stuff done, my dad says why not do all the work in the shed, with the stuff in there and all the other tools, arcade spares etc it would be very difficult, so roof over patio and I could carry on if it was raining, plus I don't want everthing covered in wood or metal shavings and how can you lay an arcade machine out, rebuild and stand up, better outside plus you have perfect light to see as well
Now most of the bad parts sorted I can start to rebuild it, before this stage it had sat for about 2 years,
amazed it was that long but I had sorted another machine out first and then been doing engine swaps on cars as well
for the rebuild I needs to be indoors, so big sheet of wood to put side on. Could do without this amount of work on a cab but always seem to end up with the real bad stuff, not so bad when it's decent price, happy to save these really beat up machines though and make them something half reasonable again.
The first Jamma cab I had to do this, was from the tip and the guy there dropped it, then he got lads to move it and they used forklift, so it was falling apart like this was, so did same and flat packed it and in the car it all went, then I rebuilt it in my back bedroom
shame I didn't take pics of it, like this also it had damaged parts so had to come apart to be fixed
Bods2019-06-20 02:08:24
5,033CR
Good chance to give it all a clean before but One thing I didn't think to do before reassembling it, I should of scanned the front artwork
Quite a bit to this cab interally. One reason it was in bits for around 2 years was I had to quickly work in Op Thunderbolt
New Base aligns nicely
Not sure why this was all broken, only the bit inside where coins drop through from Coin Mech, it still had original Coin door and Multi Mech, the usual reason these get cut out is when Ops changed from S10 Mechanial Mechs to Electronic Mars ones, so cut that out because they don't line up. can't replace it when rebuilt so another job done
Now have to re drill the holes for dowels in new corner
This control panel bit of wood has letters scratched into it, also where the gun goes it's very worn and scratched, the metal pivot is worn so gun sits to low down and wobbles so I needed to do something with it
5,033CR
The under side looks much better but I don't know how I was going to cut out the same slots in a circle for the gun bolts to turn in, the gun it self has built in stopper so this is just for the bolts to clear under gun, so I decided to make this the new top and cut it out underneath to fit the gun plate in recessed, then the gun sits higher up so problem sorted
Time to get the cheap router out, really need to get a better one as I use it quite a bit now
So 2 issues sorted, top looks much better without writing on it
Glued it back together but don't have enough clamps so had to put heavy items on top to make sure it's together right and bolt the new base in place. so nice to get it back again after being in bits for so long, because the base now has the wood top for wheels to bolt on, at the back it covers the bottom cab air vent, so quick alteration to make sure there clear
Nice to have it back upright again
patloz
844CR
Looking good.
You are putting in the effort in I think about achieving until I get In the garage and lose all enthusiasm!
I have big sheets of 0.7mm black textured formica I bought to do my Gauntlet cab if you want to completely recover the sides.
Was hard to get due to the width of the Gauntlet cab which is the same problem here.
Same stuff you get on the front of Atari cabs.
patloz2019-06-21 16:08:38
5,033CR
Cheers anyway matey
I dont usually go to far on the cabs, mostly just repair and get working, this was in worse state than i thought but dont mind the challenge, nice to rescue cabs in this state. Sides arent too bad, alot is dust and some scratches, hopefully someday we'll get full scans of the lower artwork
I'm just happy to get the machines i wanted what ever condition is, main thing i can play it and thats what drives you to get it back together and working
5,033CR
Gave all the wiring loom a wash
Quite Popular from the Coin Counter
After 2 years it's fun remembering how it all went, good job I take photo's of pretty much everything, don't know what you'd do with out digital Camera's
Nicely Powder Coated Metalwork and Coin door
Whole inside had thick layer of dust/dirt
Cleans up nice though
Looking Better though
Bods2019-06-23 01:06:48
Shinydaz
809CR
Great effort, I'd of kept my OP wolf if it was the electrocoin one and not the huge US version. It's a great game and everyone loves it at parties. Yours will be great when its finished.
5,033CR
The full size cabs are huge, these are great size and this type cab is on front cover of OpWolf for Spectrum and Commodore port
When you had games for the old home computers like Op Wolf, Chase HQ, Buggy Boy etc, you never thought you'd own the machines one day pictured on the front covers
5,033CR
Next the PCB/PSU board, Very Dirty so strip down and clean.
One of the Faults you get with Sound is the Fuse Holders Dirty, so made sure there all cleaned up good and the fuses
Some of the wires were a bit chewed up and others joined with connector blocks so sorted that out
Cash Box Door fitted
Mirror had layer or dirt both side, Probably wouldn't of registered shots with all the dirt even if the gun was complete, same on the monitor and inside glass
Nice to get the monitor and boards back in, these things take up space, the monitor has been lying around for 2 years with risk of getting broken so great to get back in cab
5,033CR
Mirror and boards back in
Machine working again, nice to see it fire up after so long, just Gun to rebuild, Coin mech to fit. Don't seem to have many photo's of the Gun, hadn't took any of it when stripping it down so took some working out putting it all back together and finding all the parts and screws, bolts n springs
The Guns are pretty well built on these machines, Only thing is the main pivot it turns on wears down, that led to mine being a bit loose, the gun hit on the glass, also had worn into the glass retainer and worn into the front aluminium corner, that's another reason I routed out the wood so when the base fitting underneath control panel the gun sits higher up, at some point I will fit some bearings so it turns better
So I had got the mechanism back together, then realised I hadn't put the plastic cover in place, so apart it came again
Grenade Button back in
5,033CR
Coin mech and original Electrocoin Credit PCB installed and tested, new bulb fitted, 6V on these I think and they don't have one fitted, so I installed the Remote holder and cable so you can get to the monitor controls, not easy to setup in these cabs without
So that about finishes of the machine, shame the Artwork isn't complete, I scanned it anyway but need to get some complete art, have got one part of the artwork from Muddy though, so get that stuck on
So for now the machine is finished, I did have an issue with the gun not registering shots after rebuilding, took me a while to figure it out but can't think what it was now, I really should note the things down as I don't remember stuff like I used to, might have been a bad connection as the board wasn't even touched. The PCB out of this one I put in the full size to sell as it was fully working, so this has the PCB that came in the Pizza Box from Arcade Warehouse, it had Sound issues which was partly the fuse holder and then some other sounds problem on the PCB, got that fixed and machine fully working again.
Nice to play it again after so long, was shame to loose my other cab being first thing from ebay but I sure like having Thunderbolt as well. My favourite part of the rebuilt is the New Base, wanted it to be same height it was, look like the base is on the floor and not wheels, don't think anyone would notice, so much easier to move about though, don't know why they didn't have wheels on
Just needs some T-Moulding at some point and the Start Decal sticking back on, hadn't put it on till I'd scanned it
vids
139CR
If only my project one could finally see the light of day ?? really nice work love op wolf and miss my op thunderbolt was a cracking 2 player game .
Chopper79
668CR
I recognise those yellow skyways! Is that a MK1 tuff burner? I sold mine to a member on here, but regretted soon after. At least I got another MK1 though.Chopper792019-06-28 10:18:01
5,033CR
Cheers guys
To be honest I'd never really done much wood work stuff, make a steering wheel and pedal to use for driving games on the Amiga, can't think of anything I'd really done much until I started buying These machines, and as many of mine are beat up ones I've had to learn to do the work, the first was the damaged jamma cab, someone must of broken the front out to get the money which is why it was dumped I guess
Yes Chopper
Early Mk1 Tuff Burner with the Foam Grips and metal pedals, I did have Super Tuff as well but like a fool sold that, still got a nice Extra Burner as I used to have one, my favourite wheels at the Tuff's though so I have some white ones I was going to put on that but keep original wheels too
5,033CR
That would be awesome if you don't mind taking the time to do it👍
I had a go the other night, I added photos again but get an error, seems the site changed the amount of letters and photo's at some point in single post which is reason photo's not showing, so I'll do a new thread and copy the text and spread it over more replies
