I'm currently working on an Outrun Cab to Cannonball interface.....
This has kept me quiet for quite a few weeks....
More updates to follow, but basically allows you to almost 'plug and play' a PC running cannonball via usb and audio into an Outrun Cab.... you will have to sort your own video options out, via Arcade VGA and Video amp board (if required) or a VGA monitor ( not quite in the spirit of the project though)
I'm still at the prototype stage, but basically all the connectors are the same/similar as the origonal game pcb and we should also be able to use the motion control on the sitdown cab, and the audio mix down for the sub woofer !! - All Outrun I/O, Shaker motors / knocker / brake lights supported and all that !!!
I'm going to get 3 proto pcb's made up in the next couple of weeks, then onto testing, and hopefully produce some diy kits in the summer......
Watch this space
Chris Whites Blog is here..... <BLOG>
He is also helping me by supporting this interface in his project and we already have some results.... It's basically an Arduino UNO Outrun 'wing' and will be called "The CannonBoard".... Most of the Arduino firmware has been written already by myself and tested by Chris...
Also will be looking at other hardware platforms (such as Rpi and/or Odriod) and also if I can find someone to help ??. a virtual joystick driver so you can also run other games (like Outrun 2) in your original cab
(Possibly even using force feedback to move the cab with the steering wheel !)
Cheers, Colin
ColinD2014-01-30 21:05:46
Watch this space
Cheers, Colin
