Pay someone to service my BO MX7000
Lastmarine
0CR
Hi Guys I'm new here.
Browsing the net in search of an engineer with experience and a willingness to service CRT TVs in 2019 is proving a challenge. I figure there must be someone in London offering CRT service and repairs but alas I couldn't find any. Which has led me to your wonderful forum. I've seen mention on various threads that there are some members here with the experience in such skills, and I was wondering if anyone would like the job of servicing and repairing my Bang & Oulfsen MX7000? For a fee obviously.
I'd like to do the work myself but my knowledge and experience with such things is very limited. I have replaced blown or bulging caps twice on my Samsung LCD tv and kept it going for another 5 years, but LCD and CRT I believe are very different and the risk and skill involved is far greater. Plus I dont care about the Samsung whereas I truly love my MX7000 and would hate to break it.
I live in Surrey in a place called Leatherhead where the TV lives in my gaming room which is a garden cabin. If anyone is in the south western region of London that would be perfect but I would happily drive if necessary to anywhere in reason. Can go into more detail of the faults if anyone is interested?
I hope to become more of a part of the forum as time goes on. Thanks for reading and sorry if this is extremely boring.
CHRIS
robotech
823CR
The b&o tvs that i have had come apart nicely all small boards that are clipped together cleverly around the bottom of the tube
Was easy enough to take apart and recap if you have soldered and recapped anything before
Just take photos of where the interconnecting wires/plugs go between boards
A lot of caps though from what i can remember
Theres got to be some old tv repair shops around still that can do
Crt,s if you dont want to have a go yourself robotech2019-11-30 01:49:36
Lastmarine
0CR
Monstermug said:
whats wrong with it?
Well picture and sound seem unaffected which almost lull me into contining to use it, but I've decided to repatch all my systems into the LCD after the issue with the B&O appears to have worsened.
At the first the issue was a low level intermittent tick sound which was accompanied by a small flicker in a random line of the picture whenever the tick happened. Almost like a small power surge. This behaviour would occur when the set was first turned on but would die down after 5 mins or so when the set warmed up. However I noticed this fault appeared to be getting worse ie more ticks when powered on, as time went by.
A week or so later now the ticks have stopped completely but instead there is a worrying sound coming from inside the chassis. Sort of a buzzing 'Schrrrrrr' sound, again this is most apparent when the set is powered on and does subside after awhile but since, as before it appears to be getting worse, I've made the decision to simply not use it anymore incase something is about to blow. I'd imagine there could be quite some damage if one of the big caps goes and that could make repair perhaps impossible.
Thanks this is good to know. Perhaps I could post pics of the inside and you might like to see if you think anything is obviously amiss. My soldering is not the best but I can handle an iron. My fear would be with the increased power cycling through a CRT, a bad solder join could be a potential fire hazard? If all else fails I guess I'll have to take on the job myself but I would prefer a pro for my own piece of mind. Even if it meant a me removing the board/boards and sending somewhere Lastmarine2019-11-30 08:05:27
Lastmarine
0CR
I assume fans arent usually found inside CRT Sets? Just wondered if that might be a culprit of the noise from the chassis Lastmarine2019-11-30 08:15:16
thegreathopper
1,162CR
no fans in the 7000, I took one apart recently.
Sounds like a dry joint, loose connection or cap,, take the back off and have a look, you may see the fault immediately.
There are 4 torc screws and the whole shell slides off.
Lastmarine
0CR
Hi. So I have opened up the set, you were right it is very easy. After some head scratching I worked out how to pull out the innards and open them into the servicing position. I also removed the AV board and couldn't find any faults there with caps or joints.
From the way the fault appears, I get the impression that the issue will most likely be found on the main motherboard where the power supply is located. looking over the caps that I can see it appears to my untrained eye, that the caps look okay. However to truly inspect the board properly I will need to remove it completely from the chassis. To do this I believe I need to remove the all the high voltage wires which concerns me some. is there a preferred method for removing this board and dealing with high voltage areas of these sets. I've left the set unplugged for over 24hrs. Is that sufficient to decharge any leftover volts?
here's some pics.
https://www.dropbox.com/s/gkimxjygz0anc4d/20191201_142006.jpg?dl=0
https://www.dropbox.com/s/q8aqcoxunsqoe5u/20191201_141735.jpg?dl=0
https://www.dropbox.com/s/lc7gpq0k5d3q2an/20191201_141910.jpg?dl=0
https://www.dropbox.com/s/bs3ncag1q1pn2z8/20191201_141950.jpg?dl=0
https://www.dropbox.com/s/9uf5ubbcuq6neil/20191201_142106.jpg?dl=0
thegreathopper
1,162CR
instead of disconnecting things, first turn on the TV and see if you can see where this buzzing sound is coming from.
Do this with the back off but don't touch anything while doing this. The fault may be obvious.
good luck
Lastmarine
0CR
Ah yes good advice. I have done so and despite it being rather a scary experience I have documented the issue on video.
Definitely seems to be coming from the main motherboard. Particularly the large red thing. I am going to assume that's a large TMR? As you can hear if you watch to the end, a worrying sparking sound suddenly starts up out what appears to be the large black power supply to the right of the TMR which I assume feeds power to the tube. I think perhaps eiher one of those might be the culprit but it could of course be something else. Perhaps you could have a watch and see if anything clicks for you?
I should add thankfully there is no smell of burning or electrical damage coming from the set but I didnt leave it on long as you can see when I panic and switch it to standby.
https://youtu.be/VQpVFonfg2k
lix
546CR
That's most likely the line output transformer (the black block with a thick wire connected to the top of the tube) developing a leak of high voltage which is arcing / discharging through its insulated body to something nearby ie. the rest of the circuitry, hence a slight distortion on a picture line when you hear a click.
Generally that is usually game over for that particular component as it'll only get worse if you continue to use it, either the transformer will burnout or it'll kill something in the horizontal scan circuit.
Now personally I have managed to rescue a couple of line output transformers, sometimes it's as easy as giving it a clean with a brush to remove all the accumulated dust. That's a very rare case though. Another one I fixed by wrapping PVC electricians tape around the base of the housing where the thick EHT wire goes into the transformer, once again that's a rare fix.
However some of the transformers I've attempted to fix have just ended building up such a high charge that they've eventually discharged with a massive zap and gone and killed the board. So ideally you'll need to check to make sure it's 100% the transformer, and then source another one, which with a TV like this is probably only going to come from another set. I don't know. Unless B&O have some good spares service going on.
Try turning the lights off and see if you can see where the transformer is arcing from. And yes, give it a day or so to discharge before cleaning it with an artists paintbrush or something similar.
Lastmarine
0CR
Thanks alot Lix. I did worry that if the issue was related to the transformer there would likely be little I could do to fix it. I will certainly try and clean the area once its had some time to discharge. I found this excellent thread on the B&O forums from a while ago which talks through replacing the most likely failed components. No mentioned of the transformer though. Also shame imageshack has removed all the photos. Good idea on the lights off recording. Will try and have a go
https://archivedforum.beoworld.org/forums/t/24571.aspx
Lastmarine
0CR
Would u recommend using isopropyl to clean the area in and around the transformer or just wipe away the dust with a dry brush? There is a fair amount of dust in the tele and even a large dead spiders nest
Lastmarine2019-12-02 08:38:32
5,020CR
Inside the transformer is thousands of turns of hair-thin insulated copper wire, to get rectified mains voltage up to 30kV.
Over time the insulation breaks down, so I’d imagine there’s a fair possibility of arcing internally.
Edit: sadly it’s the sort of reason why folk are mad to pay lots of money for old broadcast monitors and TVs sets as they’re full of obsolete components. At least there’s a fair amount of spares around for some arcade monitors.John Bennett2019-12-02 09:29:46
Lastmarine
0CR
Thanks John. I think it may well be looking like replacing with a spare part is the only solution. I'll remove the board anyway and see if I cane see any other issues. I've heard the cap for the transformer is sometimes at fault.
3,282CR
It's almost certainly arcing from the lopt as said above. If you've got an air compressor, that's probably better to use that to blow the dust out rather than a brush. Is the room damp in any way? If so then there's the possibility of HV trying to escape from a possibly slightly deteriorated anode cup on the back of the tube. Also, do you notice any problem with the focus of the picture (sharpness of the image) when you've first turned on the TV? If so then you may have a problem with the neck socket (easily replaced). That lopt appears to be of the type that doesn't have the focus or screen voltage controls on it, as such these would be elsewhere (sometimes lopts can start to crack around the focus and screen controls).
BarrySlisk
162CR
Does anyone know how many pins the neck has? Can the tube be used as a spare for a monitor? Loads of those MX7000's (and MX4000's) in Denmark.
BarrySlisk2019-12-02 15:17:09
Lastmarine
0CR
Oh my that is amazing thanks so much eggplant. I'd have never found that on my own. That could well be a life saver. Even if the issue wasnt related to that it's worth getting the part while its available still. I'll wait to see if it's the correct one. Lastmarine2019-12-02 22:03:21
