Looking for some help please! I'm trying to track down a 5v rail short to ground, the problem is on the cpu board, short of desoldering every chip and decoupling cap how can I narrow it down? tried running it on my bench psu at 5v 1 amp to see what gets hot but my psu drops down to less than 1v due to the short! Could a tiny decoupling cap take out a 4 amp fuse? I thought it would just burn up!
Board was running prior to this but started resetting and the longer it was on it would go into a reset loop and now it will instantly take out the 4 amp logic fuse.
Things I have tried
doing an ohm check around the board to try and see if I can get close to the short area but don't think my fluke is sensitive enough, getting 0.3 everywhere.
Lifted the 2 tant caps, removed every socketed chip, removed the 2 electro caps in the 5v rail, lifted one end of a few decoupling caps that I thought might look suspect!
The board is a sega whitestar and the schematics are available here link
Would welcome any advice?
Thanks Ronnie
Things I have tried
Thanks Ronnie
