PS1 Classic : AutoBleem or BleemSync?
Hitesh
205CR
My PS1 Clsssic Mini should arrive any day now.
Which of the hacks should I go for? AutoBleem or BleemSync
Any preferences of DO's and DON'Ts? advice?
Flinnster
The Dino King
29 (100%)
2,566CR
Definitely Autobleem to start with, I'd say. Run it from a USB 2.0 stick in the right hand controller port.
But.. to enable firmware changes you actually use the Bleemsync image.. this backs up your firmware etc..
I'm using a firmware mod to enable me to plug USB 3.0 256Gb stick into a y-cable at the rear of the PS1 Classic. This means both controller ports are free for 2 players - but you don't need to do this initially.
For AutoBleem, use hi-res mode and scanlines on 75% brightness for the best look on most 3D games. You may find the PSC isn't up to handling a few games on this display mode and will frame drop occasionally.
In that case set it back to standard resolution mode and disable scanlines.
Most pure 2D titles like Metal Slug, In The Hunt, Mr. Driller, the arcade museum / collection packs will also exhibit a few tile edge lines with hi-res mode on, so they'll need to be run in low res.
I've not tried wireless controllers yet, but I'm told they work fine with a suitable USB receiver.
davey d
479CR
I Cant remember what I run on mine, but as above its got USB OTG support, so i have a usb splitter on the back. Power goes to one, usb stick in the other leaving both from controller ports free
Flinnster
The Dino King
29 (100%)
2,566CR
If it says 'Autobleem' all over the menu background, it probably is that.
If it doesn't, it probably isn't.
Helpful eh?
Hitesh
205CR
Thanks for the responses.
I think the dual setup makes sense as you are using BleemSync to update the hardware but Autobleem is better eye candy?
