Question: soldering iron PSU
Spanky
580CR
I've got an ancient Weller PS‑2D, which has a transformer inside. I would like to replace this with a switched mode PSU, is there a catch at all or a reason not to do that?
big10p
Coins detected in pocket!
5,627CR
Because I volunteer at the local repair café and I want to reduce the weight of the amount of stuff I take along.
A portable iron might be an option. I got one of these a few months back for doing work inside cabs etc. Used it loads. It's been fantastic and will even work off a battery pack.
Ace`
PlanB contributor #1
36 (100%)
3,748CR
I suggest a T12 or T245 knock off iron from aliexpress/amazon. I use a Geeboon tc22 and it's a fantastic JBC knock off, and I went from a high end Metcal before that.
4,594CR
Looks quite neat that, are the extra tips cartridge type that just pull out push in? says it heats up superquick so assume the element is in the tip like Oki Metcal
big10p
5,627CR
Yeah, the tips have a ceramic base with the element in, I guess. Just need to unscrew the thing at the base to remove the tip.
Cable could do with being a bit longer, but it's a nice rubbery one that won't tangle. As I said, works off battery pack, but might struggle to reach max temps off one. Takes a bit longer to desolder big joints. Probably a better battery pack than mine would be in order. Very handy tool.
