R/tuned cab .. drive board not connected to main board ? Errror message Help
7,229CR
Also in respect to the reset button on the ffb motor driver board …
When is it applicable ?
Anytime after power on ?
During looking for ffb - steering ..
In test menues ?
AndyGeezer
575CR
Reset button, resets the motor board to initial state (think of the reset button on your PC) - it puts global power levels, etc all to the default settings.
There is an LED on board.
the LED flashes red - which indicates, the board is on and waiting for communication, once communication is made, it will be solid red.
7,229CR
Thank you Andy
Yeh I have a Constant red flashing led
Waiting to connect Só could be not getting commands from lindbergh .
Só flashing red I guess at least is a good sign :)
7,229CR
I have an option I. Have not yet tried .
I have managed from 2 non working Lindberghs now made a working on the bench at least a working booting rtuned lindbergh .
I have so far only used a Marco multi Lindbergh to test the ffb in cabinet x2
Across both cabs .
Só on my return home I will be testing the Lindy with r tuned booting . To see if this one wakes the ffb up!
7,229CR
Regarding the ground loop on the ffb motor driver pcb
838-14592-01
That was normally omitted in uk but included in usa .
Is this because the wall sockets in usa & Europe don’t carry a ground ? 🧐
And do require the separate grounding as an extra option if you like ?
As uk plug brings the ground to the cabinet chasiss ( shared Earth )
