Re-Wiring a Sega Saturn Pad with a DB15 connection
MarkGrossi
100CR
Is there anyone here that can re-wire a Saturn pad with a Db15 connection, or know anyone who can? If so, let me know.
Very much appreciated :)
Mark
Fantazia2
2,209CR
You can't just rewire a Saturn pad to DB15 as it uses data based connections and not just straight grounding for buttons like a DB15, you would need an external adapter to do the conversion.
There are multiple types of these adapters on AliExpress.
xMasterPx
14 (100%)
196CR
I believe you can use Sega Saturn pad but you need to remove communication chip on the PCB and then trace lines back to each input.
Of course when wiring DB15 wire you’d need to know what pin-out to use as not Supergun’s use the same controller standard (common being HAS Supergun pin-out)
