Reducing USB input lag?
Fuzzy
18 (100%)
564CR
Tried MAME on 2 PCs, one running Win 7 and one running Win 8 - there's slight lag that I'm sure is down the the USB input rather than the screen response time.
Does anyone know a way to reduce input lag from a USB controller?
bbz149
26 (100%)
1,608CR
Think one step ahead
Fuzzy
18 (100%)
564CR
joe34 said:
hey which usb controller are you using, and if using a usb adapter/converter also, let us know which
Hi
I'm just using a generic USB controller, direct to the USB port, no adapter/converter. Thanks.
joe34
448CR
ok for the first test then, just try whatever game you are playing but instead use a usb keyboard
are you getting any lag with the usb keyboard?
tazfaedodge
91CR
Did you have any luck sorting out the lag?
Yesterday was the first time I have had a good play on my MAME system and found that the player 2 has a far bit of lag on the joy and some of the buttons.
Nick
minwah
238CR
What controller?
I have hacked some cheap SNES copy pads and not noticed any lag. I've only done this for cabinets with one set of controls though.
tazfaedodge
91CR
I have the I-Pac 2. All the connections are good and tight no loose connections.
Running MAME with the Maximus Arcade Frontend
PC: Tiny XP, Core 2 Duo with 2 GB ram 320GB Sata HD
Everything has been up dated.
This is my first system and not sure if I have missed something in a setting somewhere.
Nick
minwah
238CR
tazfaedodge said:
I have the I-Pac 2.
I haven't used a recent one (I think they are USB only now?). The only think I can think of is to check you are using a USB 2.0 port and that the 'high speed' drivers are installed and working. Also avoid using a USB hub.
If you have an IPAC which can also be plugged into PS/2 (& your PC has a port) it might be worth trying that too.
