Solved Remove pots from touring car/le mans steering assembly.
Shun
489CR
Evening,
Does anyone know how to remove these pots from this steering assembly/motor? I assumed I had to undo the grub screw and the cog bit would slide off then I could undo the nut on the pot and then remove that. But undoing the grub screw does seem to help as the cog part won’t budge. Just wondering if anyone here has dealt with these touring car/le mans steering assemblies. Need to replace the pots as they don’t have a consistent resistance when turning and therefore the steering is very “jerky”
