Solved Robocop bootleg conversion help
Jacmar
771CR
Hey guys,
I've been messing around the last few days with a DragonNinja bootleg (I've had for ages but don't play) trying to convert it to Robocop ..
I'm close to completion but have an issue where the screen freezes (code continues to run) during the attract mode on the animation of the gun drawing from his leg ... I believe on the Robocop bootleg graphics pcb, there is a TTL chip with a leg cut, which (when cut) should solve the freezing issue. But I cant find any decent resolution pictures online and I don't have a Robocop Bootleg myself. So I'm asking if anyone who does have one, and could spare the time, to take a few decent pictures for me of the graphics pcb, particularly of any IC's with legs cut !?
🙏thanks
Jacmar
771CR
Amazing thanks mate! if anyone else wants to chime in first and save Lurch the job, go for it !
In fact please do so anyway, there could be a few different versions of the circuitry of Robocop bootleg (there is for DragonNinja)
so the more pics the better !!!
Jacmar
771CR
Cool, I'll give that a try , thanks a lot
Don't suppose there's any chance you could do a picture of that full pcb please ?
Jacmar
771CR
Thanks again
I tried cutting that LS138 pin but it just ruined one of the background layers .... hmmm
I see a few differences to my board set ... more investigation needed !!!
Jacmar
771CR
Ah ok I'll try that out..
could I be a pain and ask another favour ..if you get time, could you continuity check a couple of signals for me please
Specifically the 2x 27C512 character roms that look to be labelled A22 and A23 on your board
I'm particularly interested in both their Pin 1's (A15) and Pin 27's (A14) and what they are connected to ... each other, toggling signal (if so from where), tied to gnd or +5v
Thanks!
Lurch666
21 (100%)
4,356CR
The pins on both chips are connected together pin 1 to pin 1 and pin 27 to 27. There's a patch wire joining the pins 1 together. A trace goes from the pin 1s to pin 9 of an unpopulated LS157 (the one with the cap between pins 8 & 9) and pins 9 &10 are connected on both missing 157 places as are pin 12 &13 with a 471 cap between pins 9 and 8 (GND).
Constant activity on pin 1.
Pin 27 has a trace that goes to pins 12 & 13 of the same missing 157 with the cap.
Brief activity on pin 27 during intro with a bigger spike when robocop draws his gun (where yours crashes) with constant small spikes during demo gameplay.
Jacmar
771CR
Amazing thanks man !!!
Does one of those ROM's (probably A23) pin 1 have a cut trace to +5v by any chance? (and then tied to the other pin 1 with the patch wire) ?
