They’re 5k pots and I have some spares so swapped the green one and no difference at all.
It’s like the green is just way too high by default and the only way to get the colours correct is to turn it completely off. Then everything is too dark and raising the contrast and brightness to lighten it causes the red and blue to bleed.
The neck board has a sub contrast, red green and blue bias pots and it also has red and blue gain pots only. Unless there’s any pots elsewhere for colour, then this can’t be solved by adjustment.
I can get really strong green, red and blue colours just can’t get them to work together to get a clean white. The white Naomi splash screen is a yellow colour.
I just want to rule out the tube as the problem before I spend money on chassis repairs
