Scared Stiff booting problem
Bazfish
Lover of Blue Elephants
37CR
Hello and i hope everybody is doing ok in these troubling times.
With time now on my hands i have started work on my many games room related issues.. the first is my Scared Stiff. In brief.. with everything plugged in i get the AV board single tone and then no boot. LED501 is constantly flashing. If i remove EITHER of the CPU ribbon cables the game boots and plays but with no sound or DMD. All fuses have been checked, all voltages appear present and boards all inspected for damage / blown components as well as misplaced connectors etc. This was a fully working game but a few years dry storage have apparently not been kind
Im stumped so before i delve deeper can any of you fine people guide me down the correct path!
Help! I miss the mistresses dulcet tones!
Many thanks in advance.
Baz
Bazfish
37CR
Thanks for the reply guys. Already been on Pinside Colin and saw that link.. very useful.
Battery's all checked but also removed.. no help there im afraid. Very strange one this.. looks like further investigation is required.. seams to be stumping everyone! Lol
SUPERSPRINT
1,033CR
You’ll need the batteries in. Not sure about wpc95 but gottlieb system 3 won’t boot without batteries. Have you pressed the cpu reset button? Chances are some components are out. Worth a recap on the psu board. Find the manual, they are excellent for troubleshooting.SUPERSPRINT2020-03-30 09:29:42
Bazfish
37CR
Indeed so :) It will boot without the batteries.. just a pain doing it blind without the DMD! Lol.
Batteries are back in now anyway. This problem is screaming out as a power problem but all tests check out ok thus far. I have the original manual to hand and it is indeed very good
5,526CR
I know those combind audio/visual boards do fail... Might be worth looking up what the symptoms are of a faulty one.
5,526CR
That says it's a CPU issue. Did you leave the batteries in the game? Or were they in that expansion board some WPC CPUs have?
Bazfish
37CR
It was only six months and the batteries were brand new. No signs of any corrosion or visual damage on any of the boards. Very strange
Bazfish
37CR
Unfortunately not.. it’s the newest game I have. Loads of everything else but no WPC 95 spares.
Macro
1,990CR
Looking at the schematics, the bit that jumps out is the 'low voltage reset circuit' - can you see what this is kicking out 'cos if it's holding the line low then that would stop it booting.
JESSYBR
163CR
have you tried replacing the capaciters and bridge rectifiers???
common problem. my dracula had problems that looked almost the same as yours
good luck
Bazfish
37CR
Excellent leads gentlemen, will look at both when i next get the chance
Many thanks
Bazfish2020-04-02 09:41:47
