Scratched cocktail glass
7,961CR
Fuse is short …
I didn’t expect this to be this simple,
Was expecting to remove transistors .
Also 2 spare fuses I found in corner of cab are what’s required .
I wonder as +5v requires a 6 amp fuse
And the other 3 rails only use 1A if the fuses left in cab will be all 1A only or 1 & 6amp . Will find out Tomo
Will test it tomo with replacement fuses hopefully . If the spares ones ain’t blown as well ;)
eliotcole
1,023CR
Got a box of them things somewhere, mate ... can bring up (but you can likely Amz them quicker) if you need.
Fuse is short …
7,961CR
You mean the missing fuse ?
no ..
My issue now is I don’t know how to wire this thing up to power .
Brain fart !
I will use a stepdown type I use for the cabs or consoles ..
2 prong usa type ..
But my iso step down has 2 taps to form the 100v and it total spun my head !!
7,961CR
Right ok back to this faulty psu …
After trying to wire this thing up tired enough to sleep standing
Up I went to bed .
Now is the next day and I’m slightly more awake .
Got this wired up ..
Here are my results
7.99v+
On the 5v+ that worked fine in the cab
I have
At the fuse for the outlet ….
Nothing ?
At the -5v that did nothing in the cab
I have
-10.50v
And last of all -12
-17.68
voltages with out fuses occupying the holders
Is
For the +5v
Nearest the caps I get nothing
+5v opposite side of fuse holder I get a good -5v
Here
-5v without fuse I get
Then -16
Opposite side
So basically it’s screwy
7,961CR
So off that tap of
T2 I get a great +5v and the +5v adjust pot works great to adjust it ….
So between the tap and my fuse something ain’t right ..
Will check schimatic
7,961CR
All my 6 ground pins read 450 ohms to the -5v …
And buzz for a split second everytime I make contact ..
So I guess I have a failing decoupling cap possibly
Small caps
7,961CR
This High speed , high voltage switcher
I Shorted last night .😳
So 5 on way .
I removed a tantalum cap on the +5v line as these are prone .
Once removed .. no change on my voltage issue but a transistor started to click /tick faster or not at all depending on how I manipulated the 5v pot .image.jpg
As this tant seems to bridge the 5v line and ground plane I thought this could be what’s causing my 4,5v on my grounds .. if it had failed
But I didn’t .
