Sega digital amp 3.3v , Gnd , vol help
7,333CR
Iv got no wiper action..
Best I have got is speakers behaving as rears ..
Nothing on r-tuned ..
I think my speakers are wired wrong perhaps ..
My paddle down is stuck on ..
Also
Só I’m going to try removing the paddle down wire from the I/o
To see if the i/o is faulty ..
See gear position down ..
I think it should read OFF
On a plus cab is wired for a 5 gear shifter 😊&
All lights work
7,333CR
Are the right pins on shifter microswitch correctly, ie it's on NO normally open and not NC
Nah it’s either I/o
Or loom issue ..
It does it with shifter removed from cab ..
If i short ground pin to up pin
In connector housing
I get up, no probs their .
When I remove Gnd from up pin
It automatcaly returns to down .and just stays down all the time ..
I read a failing I/o or a short .
I am also getting a temperamental boost button registering on /off as I turn the wheel .. will remove wheel parts and inspect that next also
7,333CR
I’m going to remove padel down pin only from the I/o connector
If it’s still held on then I/o has a short on that pin maybe a resistor..
If it’s not then has to be something in the loom ..
( can’t imagine its the loom but im normally wrong
7,333CR
Vimino dosent use the last ground … in his ringedge set up
So I didn’t either ..
Here is schimatic
Also I put multi meter on my psu 5v line that is for the original sega converter pcb and it has good 5v
7,333CR
Só to recap I have tried 2x motor driver pcbs
2x converter PCB’s
No joy
Now with the new non sega serial converter I’m getting a new error .
Original error says im not connected to The main board
New error is original point error ?
7,333CR
Tried with ground
Didn’t change anything
Not easy to make out
But I pulled the ground that’s in the original connector and used that it’s still connected as expected .. no ffb initiation.
Maybe Logic board on the wheel ?
Maybe 2 bad motor driver boards .🧐
7,333CR
This guy has it working
With new serial converter has the last ground contact populated .
Here on the schimatic
See Gnd 6 becomes SH
Then that goes to pin 1 on motor controller pcb labelled
SHD Gnd. Sheilded ground
Só the new converter dosent have this on the output ..
Só where would be the best place for me to pull thet from ?
Is it important ?
7,333CR
Didnt help ..
I looked again me the vts service and test buttons are NOT SAME across all the variations of Lindbergh racing game /cab variants .. i was looking at 24 & 26 on the jvs io pinout but then if i run Hummer then run outrunsp vts behaves diffrently ..
So im loosing the will to use a Lindbergh original hardware ..
I could emulate with Lindbergh loader which I will try next,
I can also use Lindbergh motor servo / steering mech with pc . Via universal ffb pcb I have so I have options :)
