Sega Naomi jamma
Pharo
197CR
Cheers, that's what I want to do but I think it might be outwith my skill set in fact I know it is as wiring isn't my strong point, I was hoping I could buy something pre-made or pay someone to make one for me.
I'm hoping to try the monitor tonight with a pc set to 640-x480 resolution is there anything I need to check on the monitor before I do this.
Cheers Brian
Fantazia2
2,198CR
Is there a big gap between the corners of the monitor and the bezel, from the picture it looks a bit like you have the wrong one. There should be zero gap.
xMasterPx
182CR
Cheers Brian
I’ll drop you PM later regarding the wiring.
If not mistaken as long as the monitor is connected properly to step-down converter > PSU then using PC test on the monitor should be fine :)
Pharo
197CR
If anyone is wondering where I got the topper from I asked Franco on the forum and he came up with a couple of ideas and I picked this, I think it looks great so thanks Franco.
Pharo
197CR
Another big thank you to xMasterPx who did all the wiring on the jamma loom and kick harness,also did all the connectors so everything connects exactly the way it should to the Naomi wiring so if I wanted to go back to a Naomi set up it's plug and play.
FrancoB
16 (100%)
985CR
No problem! It was a fun one to work on :)
Couple more pics. It was 3mm black and orange acrylic on 6mm clear.
