Sega Naomi Monitor Mount Bushes
whitecomet
186CR
So over the years with swapping monitors in and out of Naomi cabinets, I have now a various collection of Monitor mounts.
I want to put a default Sanwa monitor back into a sega universal. Has anyone got access to the mounts to be able to advise on the height of the mounts?
I think the mounts with about 8mm depth are for the Nanao Monitor, so are the deeper ones for the sanwa?
Also anyone know of a replacement part that I can use for the thick rubber washers that are used on these?
(picture from videotronicsuk)
FrancoB
16 (100%)
982CR
Not sure on the monitor mounts as it's years since I've had a Naomi Uni but I might be able to help with the rubber washers. Do they need to be flexible? From what I remember they just act as a spacer. If they are then they should be a very simple 3D print in PLA. If they do need to be some what flexible then TPU could be an option. Happy to make some for you gratis dude in either material if that would help. Either send me dimensions or one of the originals if you have one.
