Sega Turbo restoration
andyman
1,059CR
Bought this a while ago and it needed some work
This is how it was when I picked it up from Matt, cheers dude
Obviously
it spent some time stored at the old barn where it took on a few new
additions, cobwebs and mold so its needs some work before its worthy.
All cab hoovered, cleaned & polished, good as new ish.
Rust and missing paint/chrome galore, so out with the new toy again
And
as again, a top result. The steering wheel has some deep pits but I can
live with it and again a sh*tload of work was saved. The above took
30mins
Didn't want to mess about with re-chrome on the wheel so out came the shiny paint again
Nasty
cigarette burns allover the top of the dash, sanded most of them out
and god did it smell of ancient tobacco. Sad as I was guilty of doing
this too bitd
Sand blasted to give it a bit of texture back and a bit of satin black to bring the colour back
Had to do the bolts and screws too, all done around the cab (obvious ones
Lovely Control panel, I have some 'clean anything' spray with lemon oil. Smells good, produces a brilliant shine too
Also
did the speaker grill & pedal. Speakers are fooked, cones are
ripped away on all 3 speakers too, what a coincidence, have replacements
for the top two which are on my list of things to do later.
Monitor
had vertical collapse, culprit found to be a 10uf tantalum capacitor
but picture looked shyte, regardless of adjustments so I swapped it for a
9000. Boardset cleaned and semi working, lots of yellow on screen. All
eproms/cpu/ram cleaned and reseated and we have the correct colours
Bulbs
replaced on scoreboard (which is working), marquee & gauges. Coin
slots cleaned & lubed, now accepting old 10's & 50's
Ready to join the rest. Still a bit to do and I need t sort the speakers as I think there is also a problem with the sound.
Andy.
DanP
Administrator
2,229CR
Cracking resto Andy, before and after it looks like a different cab. I do like Turbo although I find it one of the hardest drivers ever.
Dan
cliff_poole
1,069CR
For pitting, I have found that "filler primer", does a decent job. It is basically a really thick primer that you spray on and then rub right back until all that is left is the primer filling the holes. Usually comes in a bright colour so it is easy to tell when you can stop rubbing it down.
Adrian Purser
213CR
Great job. Looks really nice. That shiny paint looks great. The only stuff I've ever used is always really flat looking but that looks really shiny.
5,365CR
bloodflowers said:
Nice job :) (and yes Ord that's a Streets one)
If you want a correct gearknob I think I have a spare still from when I restored mine.
White top is correct for streets built machine
Yes I believe that is your old one Ordy, I had and swapped with shaun at the barn for Thunderblade, I guess someone else bought it from them
It had a sound fault originally
andyman
1,059CR
Isn't it great how cabs just circulate around the group
It still has a sound fault !!, damn thing is complicated to the max, got some sounds working but not all. Mind you having no speakers doesn't help.
system11
9 (100%)
345CR
It's pretty much got a circuit for each sound, I have a couple of spare sound boards (not for sale I'm afraid) - which sounds are you missing? It's a standalone sound board, you can hook it up in isolation to a test rig with a simple jamma connector and trigger the sounds.
bloodflowers2012-08-07 18:24:28
andyman
1,059CR
Hehe, can't actually remember its been that long since I last looked, handy to know it can be run on its own, cheers for that James.
Andy.
