SLICE - A logic probe on steroids!
Equites
Chief Sheesher®
35 (100%)
3,318CR
GadgetFreak said:
Equites said:
Sounds great Aaron. I would be interested to know how it compares to a ABI Boardmaster 4000 for example.
I've never used one, but from what I know it's an active system that actually drives the IC's to test them which I believes needs you to remove clock signals from the circuit under test.
To use SLICE you run the board up as normal and then use it live on the active pcb. It is a purely passive system that monitors the pins providing useful info and checking if the logic is correct. Much like hooking up 24 logic probes at the same time with intelligent analysis to check the IC is working correctly.
It also calculates clock frequencies on any clock pin, propagation delays on inputs to outputs, can read data that is accessed on ROM/PROM/RAM reads/writes and can also calculate HP style signatures on every pin of an IC at the same time. It does not work in real time. It goes through a collection, download & process cycle so the longest continuous data set is 300ms.
It also has a Project mode which allows you to group settings and results into Projects. This makes it easy to make reference projects of working boards which can then be used for comparing with faulty ones.
Flinnster said:
Can I get a cerebral upgrade so I can justify spending £450 :)
I don't like the price point either, I would like it to be cheaper, but the hardware isn't cheap. It's reliable and accurate and allows me to get down to a 5ns sample period.
Sounds great Aaron, definitely interested in this bit of kit.
Thanks for explaining.
VectorGlow
34 (100%)
900CR
GadgetFreak said:
Added #Update 2 to first post answer a few more questions
Thanks for the replies.
You state that it's not real time, can you take us through a usage example? Maybe even upload a video? I'm going to assume that you simply plug it into the chip to be tested, power up the board and view the results on the PC software.
For those who wish to place an order:
a) Is the SLICE available now, for example if somebody in the UK was to order one now how long would it take for them to receive it?
b) How many do you have 'in stock' right here and now, or are you awaiting parts?
c) Can we see some photos of exactly what is included in the purchase please?
Thanks!
GadgetFreak
952CR
With a 10ms sample period my fast laptop can achieve around 3 updates per second, but with 300ms sample period it takes around 7 seconds per update.
a: 3-4 days
b: I have 10 cable sets made up along with clips and can obtain the FPGA units usually in 24 hours. I also have pcb's and parts to make another 10 cable sets.
c: I will hopefully get a video of Slice in action posted later this week.
dj_yt said:
Does the fact the FPGA handles 5 ns, mean the hardware will theoretically support the 74F series, as well as LS?
I have used it on boards with some F series TTL with no problems.
VectorGlow
34 (100%)
900CR
Thanks for the replies, I look forward to see a video of it in use.
kthemall
21CR
ah ok it´s like a logic comparator. i use the fluke trendar. is also a cool tool, but this one´s better and more flexible.
thx tom
gamefixer
26CR
Ijust wanted to pop in and say this thing is fantastic! I've used it three times now and it found the bad IC on two boards relatively quickly. It helps to know which "section" of the board you think might be having problems but it really did help.
It found a bad LS157 that two of my 3 IC testers said was good. It wasn't.
two thumbs way up for Slice and many thanks to @gadgetfreak for making it.
Monstermug
1,807CR
Yes and regular updates too with more devices, features added on all the time. One of the most useful tool in my arsenal. Especially if you're like me and don't have hours on end scratching your head with a logic probe. It's like a 24 logic probes and a ttl databook all in one. I've got such a bad memory these days, I loose count of pins and often have to keep counting legs over and over again let alone remember what each readings were
gamefixer
26CR
LOL! You must be my twin brother! I do the same things!!!
