Snapper / Hangleyman PCB
jonhughes
1,140CR
I took a trip over to Nads (Equites) last weekend and he said he had a project for me. I was reluctant at first and wondered what on earth it could be (I should have been a little more thankful) because I have quite a few things on already (Need to get looking at that Moon Cresta again).
Anyway he handed me a Snapper / Hangleyman PCB which is a Clone of Pacman only cut in half and linked by a ribbon cable to make it two layer.
I got in from work early today and had a spare hour so I thought I'd fire it up and was presented with this:
It's a white screen with some black thin lines at the half way. I instantly recognised the lines as Pacman being chased across the screen in demo mode. Changed the bi-polar at 4A and I get decent graphics, however, all the characters had jailbars on them (sorry no photo). Rewind a year or so and I put a similar fault in the Tech section - identical fault, which I managed to fix but couldn't remember.
Went out for a game of squash and remembered during the game it was a dodgy socket on one of the EPROMs.
Got back in and decided to fix the sound before replacing any sockets - the amp was missing and I wanted to make sure this would work before thinking about the sockets:
It's an MB3712, poached one from a donor board and now I have static noise:
A while ago I was indeed very lucky to buy some Pacman bits from a seller. In the purchase there were a ton of chips including ROMs and bipolars all neatly labelled.
Found the legs on the chips at 1M and 3M had practically disintegrated, so popped the spares in and now I have fully working sound.
Having remembered the socket problem I decided to push the legs inwards on the chips to scratch a contact on the sockets. It's worked but they will need replacing and the game is now functioning.
jonhughes
1,140CR
I can't play it yet because I have a bespoke Galaxian adapter - it's left and right only for now and I'm not hacking this adapter (it's one of those proper expertly made printed ones).
The PCB has had a make over - the jail bars kept returning and then the colours would go funny. So new sockets are in and the board is now rock solid.
Pics to follow on the handy work.
jonhughes
1,140CR
And to finish:
Here are the bad sockets - one or more is giving me jail bars and incorrect colours. But they're all coming out. However, amazingly these have been replaced before.
I'm removing the final part of the second socket, there's plenty of dark gunk on the board after the sockets were replaced the first time round and the flux wasn't removed. It's been a pain so far.
Finally they're all out and I've cleaned up the previous mess from around the pins.
Now to solder the new sockets in and to clean up the PCB after doing so.
Shiny new sockets - board is now rock solid no glitches at all.
Don't like the look of that DC hack or the flux around it.
Solder cannon ball on the back that's really overkill and good to go.
And it's looking a lot better. Also redirected that purple wire through the diodes to hold it in place.
Job done.
