Space Firebird
Adrian Purser
213CR
I had a Space Firebird board that had a blank screen and had a sound effect constantly playing. The star field was only displayed when the board was held in reset.
The cpu seemed to be running so I put a logic analyser on the address bus to try and see how far it was getting. I ran the game in mame with the debugger and I was able to trace it to a point where it read the inputs. It did a test of the input "TEST TP-8" and if it was active then it jumped to code at address 0x3800. I could see by looking at the data bus that the real board was reading 0x40 from the port but mame was reading 0. I checked the output of the 74LS240 at 1L and it was stuck when the device was enabled, so it was probably the input of the chip at fault. I replaced the IC and the board sprang into life. The code was no longer jumping to 0x3800 and continued to boot into the game.
mozie
20 (100%)
529CR
Well done, these boards seem to die often, I have one here at the moment that works fine but the shot sound is missing, all other sounds are present, any idea where to look?
Ronnie Dent
1,110CR
I too have piles of these boards with various faults from dead to bad graphics, I made a test rig to work on them but it's beyond me!
I did send them to a repairer but most came back with the same faults I sent them off with!
Adrian Purser
213CR
This is the first time that I've worked on a space firebird and I didn't look at the sound board but I'll have a look at the schematics when I get 5 minutes.
patzik
329CR
I recently worked on 3 space firebird boards, biggest problem was the ram ic's, I ended up with 12 faulty ones in total and haven't found a good place for affordable replacements. i tried 5101 ic's but they are not fast enough. Anyhow I also had some sound problems which I fixed. I remember one of the boards had strange sound for fire, this ended up being a bad capacitor. The sound board has some LM324 amps, if sound is completely missing this is where I would look first. Also check the 555 timer, if I remember correctly this generates the vibration for the shooting sound.
Macro
1,982CR
Did you ever find a good substitute for the video ram chips ?
I think I'm going to need some ... (once I find some way to test them, trying a script on ABI 4000, but if that fails then I may just plug them into a galaxian PCB and use the Fluke on them)
