Star Force pcb
sukhbir
45 (100%)
1,607CR
Hi all,
I dug up a original star force pcb which I found in my loft,bought it many years ago decided to have a go in fixing it,trouble is it’s missing the 4 program roms 2,3,4,5.
It has a encrypted z80 CPU (315-5069) fitted,I can’t find any info on what romset is required.
any help please?
philmurr
46 (100%)
2,310CR
There are a couple of original encrypted versions (excluding the bootleg starforcb), ROMsets are starforca and starforce
I used the unencrypted version starforc and a standard Z80 when I did my high score save mod
GadgetFreak
952CR
It is possible that 5069 is the same as either 5015 or 5018, I would try both sets to see if either works?
The encryption table for 5069 has not been dumped so if neither works then you will have to go with an unecrypted set.
sukhbir
45 (100%)
1,607CR
Hi,
That's a good idea but I would give the decrypted set a go.i got hold of the set from the Web but the program roms are 16kb (27128) and two are used for rom location 2 and 3.
The board set I have use 8kb roms (2764) for location 2,3,4,5.
Will the 2 decrypted roms work?as there's no select link on the board for 16kb?
GadgetFreak
952CR
Lower half of '3.3p' should go to 2 (8m)
Upper half of '3.3p' should go to 3 (8k)
Lower half of '2.3mn' should go to 4 (8j)
Upper half of '2.3mn' should go to 5 (8f)
sukhbir
45 (100%)
1,607CR
Burned 4 decrypted roms (2764) today but all I get is a cyan colour screen and a pulsing sound,scoped the reset pin on the z80 and its pulsing,oh dear :( it looks like the watchdog is barking.
As this is a 3 board set it’s going to be a difficult repair.
sukhbir
45 (100%)
1,607CR
Thanks lurch but I don’t think it’s going to make any difference as i think it’s a data or address bus issue somewhere.
ill try the romset you have provided just to make sure.
