Street Fighter Pinball problem
Ronnie Dent
1,196CR
roadwarrior94 said:
If you have these GAL chips and you seem sure that's the fault
Would you do the repair for me?
Paul
I'm not sure to be honest, but it's a likely suspect, the chip is in a socket so easy swapped, but I have no pin to test it on so not much point in sending it to me, there is a rebuild kit for the high voltage I think? but you need to check the voltages really but might be wise to fit the kit anyway!
Ronnie
roadwarrior94
14CR
Ronnie
What voltage should I be looking for on this board and where do I check?
Also would you be able to get me a replacement GAL chip?
Paul
Kickback
3CR
Always worth checking the F5 fuse, as this controls the power to the A2 board without it only the general illumination works. Its next to the transformer in the bottom cabinet.
