Tech: Cabaret maquee removal
5,002CR
[ukvac] Tech: Cabaret maquee removal
Hiya,
Does anyone know how or what special tool is required (and where to
get one!) to remove the bolts which hold on the marquee on Atari
cabaret's. I've seen these bolts holding on speaker grills on lots of
Atari cabs but until now never needed to remove them.
I've tried all the security socket set attachments I have and allen
keys but none of them seem to do the business.
Regards
scotty
Get paid for the stuff you know!
Get answers for the stuff you don’t. And get $10 to spend on the site!
http://click.egroups.com/1/2200/7/_/5935/_/955564453/
DATA Imported from archives: originally posted by Scott Green (scotty@nanonano.co.uk)
LukeWells
334CR
Re: [ukvac] Tech: Cabaret maquee removal
Just remembered I bought mine from "Snap on tools" ... there is a van that
drives round selling tools :) Also Mac (same thing, can drives round) next
time you see one in your area run out in front of it and stop it! :)
I got a 12 piece torex driver set for 12 from MAC, although snap on sell a
8 piece for about 5 that will do the job
Luke
zepromz
77CR
At 20:43 11/04/00 +0100, Ade wrote:
>I got a set of security bits from Maplin for about 6 or 7 pounds. The set
>includes 32 bits, 9 of which are security Torx (for the Torx screws with the
>pips in the centre) and there are also some security allen keys. I've used
>these to take marquees of some cabs and the control panel on blasteroids
>also use them.
Gorf and Tron joysticks use them too. (security TORX, not "torex")
I got a 32 piece set from CPC for a tenner.
end of message---------------
while(horse_dead) { beat(); }
25% Off All Prints!
Buy one today at Corbis.com
http://click.egroups.com/1/3357/7/_/5935/_/955571121/
DesG
11CR
RE: [ukvac] Tech: Cabaret maquee removal
Its called TORX and there is also Torx-plus which has a hole drilled through
the centre, get the plus ones if possible as these do both.
DesG
DATA Imported from archives: originally posted by Des Gibbons (des@fastcarz.com)
dz1n3
Friday Ranter
37CR
Tip:- it ya ever come across the torx-plus and you only have torx driver
bits, jewlers screewdrivers breaks that internal pin no problem, then a trox
bit will work.
** Yea Yea its brute force, but so fucking what **
Darren Hatton : ).
through
Free E-Cards, Screensavers, and Digital Pictures!
Corbis.com:
http://click.egroups.com/1/3358/7/_/5935/_/955574149/
5,002CR
Cheers for all the response.
I do already have a set of security bits which include TORX which
I've successfully used to replace Tron joysticks, etc. But these
marquee ones are too deep to use a socket set with. So do I need to
get some with which are longer (i.e. not socket sets), hope I'm
making sense?
scotty
5,002CR
In article <8d2fj2+j58o@eGroups.com>, Scott Green
<scotty@nanonano.co.uk> writes
>Hiya,
The marquees on the Atari Cabarets were not designed to be removed as
they are riveted on! To remove you have to drill with about a 1/2 in
drill bit slowly until you remove enough of its head so you can chisel
it away. To replace I guess the best way is to screw them in with those
special screws with the hole on the top which accepts a small plastic
(black) cover with a pip which wedges into the hole (a la MFI furniture)
XY-Man
You can win $1000!
Just one of 1000 great reasons to visit eGroups!
Click here:
http://click.egroups.com/1/2865/7/_/5935/_/955588277/
DATA Imported from archives: originally posted by Trollian (XY-Man@pyramidm.demon.co.uk)
P-Man
International man of mystery
1,272CR
Atari battlezone Caberet machines (x2) i removed the marquee from one of
them, but XY is indeed right, they are rivetted in, they are a real pain to
remove, possible, but a real pain. I only had a pair of pliers and sheer
determination.
I don't know where the rest of you are getting the TORX and Allen key
stories from :)
Allen keys allow you to remove the lip at the top which allows you to remove
the monitor plexi and get at the monitor..
seeya!
