TECH: coin door locks, correct term? TIA
erikthecat
21CR
hi,
would someone be able to advise what the correct term is for the simple coin door type locks.
consisting of a barrel and a metal plate screwed to the non key end, fitted into a elongated roundish hole, all fixed with a large nut?
sorry for the crap description.
i'm supposing there's a myriad of sizes.
mine are required for a non standard table door replacement.
any cheap suppliers for very small quantities, i.e. one maybe two.
non massive p&p / paypal etc.
many thanks for your time.
Regards,
GaRy:)
P-Man
International man of mystery
1,272CR
Technically I believe they are caled 'barrel locks', Camlock is a
company name, like Fort Lock etc.. :)
The length as craig points out, varies, and you will need to work out
which length you need as most old machines have their own crazy length
of locks, especially in tables.
Andrew Welburn
http://www.andys-arcade.com/
Quoting Craig Walker <craig@giz10p.co.uk>:
> Cam Locks....
> http://www.giz10p.co.uk/index.php?act=viewCat&catId=6
> Click on a lock then on "more images" then there will be a picture of
> how the locks length is measured..
> Regards,
> Craig
> uk-vac@splatthatcat.com wrote:
>> hi,
>> nut?
>> Regards,
>> GaRy:)
erikthecat
21CR
thanks guys for your swift replies.
Craig, please look out for an incoming order,
i paypal'd you already.
any problems, just shout.
Regards,
GaRy:)
Ordyne
1,282CR
Cam Locks....
Regards,
Craig
> hi,
> Regards,
> GaRy:)
