[TECH] - MPU4 / Crystal Maze Problem
5,053CR
[ukvac] [TECH] - MPU4 / Crystal Maze Problem
Well I guess Crystal Maze is a Video game so its fair to post a teaser about
it on here.. (and also theres some fruity techy people too who can help..)
I today aquired (Thanks Nige.!) a lovely Crystal Maze Mk1 Cartridge for my
Crystal Maze (Mk2) Cab. But there seems to be a problem.. On the blue boot
up screen 'Resetting SWP V....etc' I get an error message saying 'No
Dataport Comms' and it will sit there and not budge.
BUT if I run the game with the back door open (where the game is on a
'freeplay') the game works no problems. I know I could run the cab with the
door open , but it doesn't pay out :(.. Its odd because I can put the
original cartride backl in and it works as normal..
Looking at the MPU4 board the 'DataPort' looks like a serial port of some
description but I know that the Mk2 board doesn't need anything plugged in,
so I can't guess the Mk1 would (or am I wrong???)
Anyway.. HELP!!
Kip
DATA Imported from archives: originally posted by Kip (kip@thedvdproject.com)
5,053CR
RE: [ukvac] [TECH] - MPU4 / Crystal Maze Problem
You have a "data Prom" in your program cart.
Basically you need a "non data prom"
The data versions are used by the big companies to link to their computers.
"Kip" <kip@thedvdproject.com> wrote:
>Sender: sentto-1013941-10938-1003864572-houseofamusements=compuserve.com@returns.onelist.com
>Received: from n14.groups.yahoo.com (n14.groups.yahoo.com [216.115.96.64])
> by siaag2af.compuserve.com (8.9.3/8.9.3/SUN-1.12) with SMTP id PAA08261
> for <houseofamusements@compuserve.com>; Tue, 23 Oct 2001 15:16:29 -0400 (EDT)
>X-eGroups-Return: sentto-1013941-10938-1003864572-houseofamusements=compuserve.com@returns.onelist.com
>Received: from [10.1.4.54] by n14.groups.yahoo.com with NNFMP; 23 Oct 2001 19:17:15 -0000
>X-Sender: kip@thedvdproject.com
>X-Apparently-To: ukvac@egroups.co.uk
>Received: (EGP: mail-8_0_0_1); 23 Oct 2001 19:16:12 -0000
>Received: (qmail 824 invoked from network); 23 Oct 2001 19:16:11 -0000
>Received: from unknown (10.1.10.26)
> by l8.egroups.com with QMQP; 23 Oct 2001 19:16:11 -0000
>Received: from unknown (HELO blueyonder.co.uk) (195.188.53.122)
> by mta1 with SMTP; 23 Oct 2001 19:16:11 -0000
>Received: from kipper ([62.31.51.11]) by blueyonder.co.uk with Microsoft SMTPSVC(5.5.1877.687.68);
> Tue, 23 Oct 2001 20:16:00 +0100
>To: <ukvac@yahoogroups.com>
>Message-ID: <FLECKDIELCIENHBFKIEECENACCAA.kip@thedvdproject.com>
>X-Priority: 3 (Normal)
>X-MSMail-Priority: Normal
>X-Mailer: Microsoft Outlook IMO, Build 9.0.2416 (9.0.2910.0)
>X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2600.0000
>Importance: Normal
>From: "Kip" <kip@thedvdproject.com>
>X-Yahoo-Profile: kipsterbloke
>MIME-Version: 1.0
>Mailing-List: list ukvac@yahoogroups.com; contact ukvac-owner@yahoogroups.com
>Delivered-To: mailing list ukvac@yahoogroups.com
>Precedence: bulk
>List-Unsubscribe: <mailto:ukvac-unsubscribe@yahoogroups.com>
>Date: Tue, 23 Oct 2001 20:16:34 +0100
>Reply-To: ukvac@yahoogroups.com
>Subject: [ukvac] [TECH] - MPU4 / Crystal Maze Problem
>Content-Type: text/plain; charset=US-ASCII
>Content-Transfer-Encoding: 7bit
>Anyway.. HELP!!
>Kip
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
DATA Imported from archives: originally posted by (houseofamusements@compuserve.com)
5,053CR
Re: [ukvac] [TECH] - MPU4 / Crystal Maze Problem
There is a sticker inside the back door at the bottom saying "Dataport
fitted" - I'll have a look tonight to see if there is anything
obvious...
Nige
Nige
DATA Imported from archives: originally posted by Nige (nigel.scott@rdel.co.uk)
5,053CR
Re: Re: [ukvac] [TECH] - MPU4 / Crystal Maze Problem
Cool..
Basically I think there should be something that plugs into the 'Serial Port' thing on the MPU4 board that your cab has, and mine doesn't so if you have any bits that have a 25-Way D-Type connector floating around on then thats what i'm after..
Kip
>obvious...
>Nige
>Nige
DATA Imported from archives: originally posted by (kipatwork@thedvdproject.com)
5,053CR
RE: Re: Re: [ukvac] [TECH] - MPU4 / Crystal Maze Problem
You have it wrong kip
You need a non data chip set. The one you have only works with a data retreival system.
I hope you didn't pay for it as you have, if you excuse the pun, been kippered
kipatwork@thedvdproject.com wrote:
>Sender: sentto-1013941-10956-1003919715-houseofamusements=compuserve.com@returns.onelist.com
>Received: from n21.groups.yahoo.com (n21.groups.yahoo.com [216.115.96.71])
> by siaag2ac.compuserve.com (8.9.3/8.9.3/SUN-1.12) with SMTP id GAA16400
> for <houseofamusements@compuserve.com>; Wed, 24 Oct 2001 06:35:20 -0400 (EDT)
>X-eGroups-Return: sentto-1013941-10956-1003919715-houseofamusements=compuserve.com@returns.onelist.com
>Received: from [10.1.4.54] by n21.groups.yahoo.com with NNFMP; 24 Oct 2001 10:34:51 -0000
>X-Sender: kipatwork@thedvdproject.com
>X-Apparently-To: ukvac@yahoogroups.com
>Received: (EGP: mail-8_0_0_1); 24 Oct 2001 10:35:15 -0000
>Received: (qmail 42190 invoked from network); 24 Oct 2001 10:35:14 -0000
>Received: from unknown (10.1.10.27)
> by l8.egroups.com with QMQP; 24 Oct 2001 10:35:14 -0000
>Received: from unknown (HELO smtp.fasthosts.co.uk) (194.74.63.31)
> by mta2 with SMTP; 24 Oct 2001 10:35:11 -0000
>Received: from localhost [194.74.63.18] by smtp.fasthosts.co.uk
> (SMTPD32-6.06) id A92462012A; Wed, 24 Oct 2001 11:34:12 +0100
>X-Sender-ip: 9d3225b4
>X-mailer: Netbula AnyEMail(TM) 4.67
>Message-Id: <200110241134484.SM00127@localhost>
>From: kipatwork@thedvdproject.com
>MIME-Version: 1.0
>Precedence: bulk
>Date: Wed, 24 Oct 2001 11:35 +0100
>Subject: Re: Re: [ukvac] [TECH] - MPU4 / Crystal Maze Problem
>Cool..
>Kip
>>obvious...
>>Nige
>>Nige
eggwheatis
cheers
65CR
Can't you just plug in a datapack key?
I have one you can have if you want.
houseofamusements@compuserve.com wrote: You have it wrong kip
>MIME-Version: 1.0
>Precedence: bulk
>Cool..
>Kip
>>obvious...
>>Nige
>>Nige
Yahoo! Groups SponsorADVERTISEMENT
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
cant you just plug in a data
Do You Yahoo!?
Make a great connection at Yahoo! Personals.
