Tech Needed: Outrun
JCRS
114CR
[ukvac] Tech Needed: Outrun
I have a problem with a mini outrun, the left hand side of the screen
suffers badly
see pic at http://www.pinckney.org.uk/outrunvdu.jpg the machine plays fine
except the corruption at the left hand side of the screen.. any ideas what
this could be ? cap ?
also the sound seems to be missing on channel.
I have ran the Test Switch and it passes all ROMS, although Rom 65 or 114
seems to put a small amount of snow on the screen for a split second and im
unsure if it suppose to do this. Any ideas anyone ?
Your help would be appreaciated...
thanks.
P-Man
International man of mystery
1,272CR
Re: [ukvac] Tech Needed: Outrun
> suffers badly
fine
what
umm, looks a little more worse than the left hand side of the screen :)
Look like RAM problem, or a ram buffer.
can't explain that one :)
im
sounds like graphics ram to me.. the snow is indicative of a screen ram
problem. if outrun is marginally similar to hang-on (i think its slighlty
the same :) then you should be looking for 2148 fast sprite screen
ram/buffer thingies...
> thanks.
screen rams aren't often checked when running self test, and even if they
are, you can have games that pass the self-test, but do indeed have a bad
ram which confuses a lot of people :)
so ram, or ram-buffer, something to do with the screen ram i would think.
hope that helps.
Andy
5,009CR
114
It puts snow on the screen as it's testing the GFX RAM by filling it with
data. Snow is normal, as long as it then clears back to the correct picture
(and it'll say RAM OK too ;))
--Cas
DATA Imported from archives: originally posted by John Cassells (john@cassells.screaming.net)
JCRS
114CR
Hi..
Ive had a look on the outrun pcb but cant find any IC's with 2148 on them..
Also the sound problem isnt a channel problem.. both channels play but half
the tune is missing.
Anymore help would be grateful..
