[Tech] Poor JAMMA Edge Pins
5,273CR
[ukvac] [Tech] Poor JAMMA Edge Pins
Non working jamma board with dodgy edges ( had some foil or something
soldered to them :) is there a 'proper' method around this or tack a double
edged jamma finger board to it etc..
Can provide pics but it aint a lot to look at.
Cheers, Joe
DATA Imported from archives: originally posted by TvTuna (postmaster@gerbil.u-net.com)
5,273CR
Re: [ukvac] [Tech] Poor JAMMA Edge Pins
Toaplan shooter! Will scrap it end of the week but see if this book thing
helps first
PaulSwan
ZZZ
1,118CR
You could try silver PCB track repair paint. It's a small bottle similar
to nail varnish that can be painted onto a PCB. It dries leaving a
conductive silver plating. I've repaired PCB tracks with it but never
edge connectors. It might be worth a try...
Failing that, it is possible to "lift" a good edge contact off a scrap
board and superglue (or a Tak-Pak is better) it down on the other board
(once it's been suitabley prepared and cleaned). use a small amount of
solder at the end to tack the new contact to the track (or use silver
paint or a small bare wire bridge if the distance is large).
Regards,
Paul.
> double
> Cheers, Joe
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
d-type
172CR
RE: [ukvac] [Tech] Poor JAMMA Edge Pins
Fixing PCB edge connectors properly is covered in Atari's The Book in some
detail (on spies). Page 1-30 (page 40 of the PDF version).
Phillip Eaton (Forth-79/D-Type/Flip-Flop)
Tel: +44 (0)1536 268424/504434 Fax: +44 (0)845 334 8195
Email: d-type@phillipeaton.com Mobile: +44 (0)7775 726366
Web: www.phillipeaton.com
P-Man
International man of mystery
1,272CR
double
non-working jamma board with dodgy edges sounds like a candidate for
scavenging parts from to me ;)
> Cheers, Joe
hehe
or am i too morbid?
Andy
