[Tech] Rom Access times
4,058CR
[ukvac] [Tech] Rom Access times
Does anyone know what the access time should be set to for reading/writing a
"27C256" eprom please (sorry, i don't know the make, the is a square lloking
S printed on them). I'm trying allsorts and just getting errors when i try
and read them. Could this mean knackered roms?
TIA,
Guddler
JCRS
114CR
Re: [ukvac] [Tech] Rom Access times
S in a Square.. isnt that Thompson .. which proberly doesnt make sense :)
4,058CR
RE: [ukvac] [Tech] Rom Access times
Not really too sure what it was as the sticker was partly over it. Anyway,
on extracting ALL the roms (okay, OT as this is a Pinball i'm talking
about), i discovered a bent pin on one of the ICCs.
Turned out to be the voltage pin on one of the sound roms. Funnily enough
when i straightened it out and refitted it all the missing sounds can now be
heard in all their glory, so i don't much care now why my burner couldn't
read them properly.
Thanks for the replies (on and off list) though anyway.
Guddler.
> sense :)
5,298CR
In article <OKEAKKLKNLLNCFCBKDFDEEJJCEAA.martin@guddler.com>, Guddler
<martin@guddler.com> writes
If in doubt try the slowest programming algorithm. Or erase the ROM and
do a zero check. The average read time of a modern EPROM should be
either 250nS or 150nS. (Probably) Some simple or vintage EPROM
programmers sometimes struggle with high impedance address/data lines
not draining residual charge fast enough to read correctly. I
occasionally had to disable the fast program algorithms on my first
programmer.
Clive Mitchell
DATA Imported from archives: originally posted by Clive Mitchell (clive@emanator.demon.co.uk)
