The Commodore 64 Ultimate
Spanky
575CR
A faithful reproduction, not just in looks but in tech specs. Instead of running a software emulation of the C64, it’s built around an FPGA.
You can plug in an original C64 Datasette or disk drive and it will run original software. It even has a cartridge port.
You can plug in a USB thumb drive and load C64 games and apps that you’ve acquired online. The computer also comes with a sample USB drive that is filled with demos and games to try. Even better, it’s easy to connect it the internet via a wired or wireless connection.
Available from March, £260.50
https://www.theguardian.com/games/2026/jan/15/commodore-64-ultimate-review-computer
patloz
836CR
I love the idea but would never use the additional features it has , I only ever turn mine on , load up the SD card and run a game and mine cost about £80 I think and I doubt i'm much different than the majority of users.
This bloke has compared the Maxi and the ultimate so you can decide if you need to spend the extra bucks.
Here
4,982CR
Would you even know the difference though ?? Not pulling it apart it looks mint but FPGA much different ? I have never looked and have no clues about it.
Genuine question,
Dave.
The advantage here is it's got all the connectivity for cartridges, tapes etc, which you wouldn't get on a Pi/PC setup.
FPGA is still emulation though, whether they omit the word or not. What difference it makes depends what you put in it. There's some stuff that's a chip-by-chip replica of the original, or made by decapping custom chips. And then there's hacky MAME C code turned straight into verilog on other stuff. Whether anyone notices when playing a game, I dunno, probably depends what MAME setup you've got running (a 20-year old port on a Pi isn't really fair).
Anyway, no idea if this has transistor-level SID etc, but at a glance, it looks pretty top-notch for mixing old and new with tonnes of features. Should be for that price, mind you. .
TheDaddy
14 (93%)
6,988CR
Thats was the answer i was after , thanks John !
Dave.
patloz
836CR
I downloaded a folder of what is allegedly every game made for the C64 to play on my Maxi C64., They load up the intro screen as if they were coming off a tape ( so slowly line by line which you can skip if you like) they also have the cracktro intro which I find nearly as enjoyable as the games itself so you can tick infinitive lives / energy etc if you are a cheating MoFo and cant beat the fan lady in Yie ar Kung Fu by yourself.
If anyone needs it i will find a place to upload it as I remember I had to mess with it to get it into the right format and split the files into alphabetical chunks for the Maxi so will save you some bother.
I cant guarantee its every game either but there are a lot!
patloz
836CR
I am away with work for this week ( Cleethorpes of all places, still has arcades but with no arcade games in ,not sure what's worse) will upload it when I'm back and post the link.
kingtreelo
17 (100%)
1,488CR
i don't want to be that guy, but FPGA is replication rather than emulation, it replicates the original hardware rather than emulating software on the fly
it's all good though, it all works the same when we are trying to do anything more than 20 years old, i could run C64 games on a phone i had about 15 years ago i imagine
4,982CR
"A replica is an exact (usually 1:1 in scale) copy or remake of an object, "
I wish that was true. Then you could pull any bit of verilog off MiSTer and use it to make a custom chip to fix a dead arcade PCB. 99% of the time you can't.
edit: But to be fair, if you go to the extreme levels, you can pretty much replicate every transistor in an FPGA.
patloz
836CR
