I was browsing through the TnF code and found an Easter Egg in the initial entry section of the game.
Make sure all switches on both dip switch banks are set to the ON position before you start this (it's only activated this way)
Start a 4 player game and enter initials as follows :-
P1 - ISI
P2 - HAR
P3 - A.L
P4 - ABO
ISIHARA.LABO (maybe the lead programmer on the game?)
This gives you a ©KONAMI 1983 message above P1 initials for a couple of seconds before the game reboots.
Figuring that it was probably the same dev team that made Hyper Sports I had look through that code for an Easter Egg in the initial entry screen and found a very similar one. The dip switch settings are irrelevant for this one but there's a little more work needed to activate it.
P1 - ISH
P2 - IHA
P3 - RAL
P4 - AB.
ISHIHARALAB.
Then after you've selected END for the 4th player quickly press and hold the following buttons :-
both P1 run buttons + P1 jump button + both P2 run buttons (but NOT P2 jump button)
This gives you a developer credits screen and then goes into an infinite loop requiring a reboot of the game.
Does anyone know who Ishihara Labo. is as I can't seem to find any info on the development team behind these two games?
P1 - ISI
P2 - HAR
P3 - A.L
P4 - ABO
P1 - ISH
P2 - IHA
P3 - RAL
P4 - AB.
ISHIHARALAB.
