This is a repost from J+ that I posted in 2012 after getting my Star
Wars, hopefully it will useful for any new Star Wars owners who want to run through
some checks before switching it on or if you have problems.
I am not an expert and a big thank you goes to ColinD for all the help and patience in helping me
with this. There is a lot of very good information available on the
internet that explains the sections covered in this guide in a lot more detail
that I will refer to but hopefully you will find it useful.
The
first thing to do is to purchase a Multimeter that has a diode setting and
ideally an audible continuity test. I got this one (GW24B) from
Maplin for £19.99 that works very well:
http://www.maplin.co.uk/digital-multimeter-with-autorange-frequency-counter-4407
For most usage you will insert the black lead in the COM socket and the
red lead in the V?mA socket. The dial in the middle is used to
amend the sensitivity of the Multimeter and should be set to the next highest
setting of what you are measuring. So if you are testing for 37v DC you
would need to set the switch to DC and the dial to 200. If you are
testing 12v DC you would turn the dial to 20.
For this guide I will be using a Star Wars Upright cabinet with a WG6100
monitor that was sold as not working. As it is an Atari classic it
has the following four key segments that enable gameplay:
- Atari Power Brick = Transformer / Fuse carriers / Bridge Rectifier /
Big Blue Capacitor and also mains and other connectors
- Audio Regulator PCB (AR2) = Various Voltage sections (where fitted)
and amplifiers (where fitted
- Game board PCB = CPU board , AVG board and Sound board
- Monitor = High Voltage PSU, deflection PCB
(Low Voltage rails, X and Y amplifiers, Spot Killer), and the tube itself
For each of these items I recommend downloading the service manuals as it will
help you figure out which voltages need to be checked. You
can get them here:
http://www.vernimark.com/arcade/default.asp?PageMode=9
http://arcarc.xmission.com/
Now that we have identified the items we are going to check we will first begin
with checking the fuses on the Power Brick and deflection PCB.
The
can get them here:
