Problem VF2 Model 2 cab > OSSC?
Skycron
5CR
OK, I dug out my OSSC and done a simple test.
VGA out from Model 3 > Extron 160xi > Extron BNC to OSSC using Startech BNC-VGA cable = No image.
VGA out from Model 3 > Extron 160xi > Extron BNC to RT4K using Startech BNC-VGA cable = Triple image, there may be a setting I can change but it's not usable.
I can't find my connectors so can't test any further, using a standard component cable with BNC to RCA adapters may be your solution.
Interesting. This is very much appreciated.
Question. When you tested the OSSC via the Extron, was it at least outputting to the arcade monitor? Then at least the Extron is working because the arcade monitor is displaying the output from it. If only the OSSC is having difficulty with the image, then at least we know it’s just the OSSC settings we have to screw with.
I had found a site that had Model 2 specific timings, but now frustratingly I can’t find it. I did find this, which has verified timings that work with Daytona USA which being Model 2 I would assume would theoretically also work with VF2 being the same board:
Based on this thread I ended up buying the retrotink vga/rgb. If you are getting a triple image on the retrotink and nothing on the OSSC that lends credence to the idea that the wiring on the Startech is non standard / wrong.
Skycron
5CR
Hello everyone,
I’ve finally done it. Cables made and finished, with the correct pinout. To start I’m just going to see if my cable will send the signal from the PCB to the Extron > OSSC, then when it does I’ll connect my other cable to the monitor to the buffered output) as well for the full signal return. For now I just want to see if the OSSC likes what I did and gets a signal.
Before I turn it on for the first time though, I just wanted to make sure the Extron switches are in the right place. This is how it was when I got it. Please let me know if I need to change the toggles anywhere. (Right now the metal switch is set at ‘Unity’, not 50% or 100%).
I just don’t wanna screw anything up.
Please let me know if the Extron switches look ok and, if not, what I should toggle them to. Thanks again everyone! Photos:
