Solved Wonderboy monsterland credit issue
jizzfu77
7CR
Hi, i have a problem with my WBML board, it just doesn't accept credits. I already tried to change the tlp 521 phototransistor with no luck.
The schematics are the same as choplifter.
Someone can help me? thanks!
sukhbir
45 (100%)
1,613CR
check if you have 5volts on (O) and (P) parts side edge connector of the board,inputs are usually tied high.
if you have 5volts then press the coin button and it should go low.
if it goes low follow to the logic ic inputs which is usually a ls367 buffer or ls368,check the outputs of these logic chip.
cannot find schematics,also as you have changed the optoisolator check where it’s output goes.
jizzfu77
7CR
thanks, if i am not wrong credits go to an ls257 (ic135). Schematics attached.
  • Choplifter.pdf
sukhbir
45 (100%)
1,613CR
Hi, had a look at the schematics.
Are all your dipswitches off (sw2)?
I presume you have replaced ic54,there are 4 data bits which come out of ic154 and they goto the 8255 ppi chip from D0-D7 when you activate the credit switch, not sure which data bit is for credit?
Using a logic probe or scope look to see the data bits change when you press credit, if you see changes then i suspect the 8255 ppi.
jizzfu77
7CR
yup all sw are off, i changed the ic157 because the coin is on pin 15 on the connector, then go to ic157. I dont know if the 8255 is for credit or for coin meter, in my board the uln2003 is not present so no coin meter. I will check the D0-7 but if i push the credit button the signal goes low.
sukhbir
45 (100%)
1,613CR
have you got a bootleg pcb or original?
inputs at the edge connector for system8 credits are O and P Parts side.
anyways if the outputs go from high to low on the opto you need to see if databits do-d7 change at the 8255 chip When you press credit switch.
jizzfu77
7CR
checked d0-7 on the 8255 it has some actvity i think because are signals from the roms, nothing changes when i press the credit. On the opto i have the signal from high to low on INPUT, in output i have some activity and when i press the credit that activity lower by a bit (but not to zero).
sukhbir
45 (100%)
1,613CR
Oh right i see,that will be the data bus bit At pin 16.
decrease the time for the signal on your scope so you can see the signal better and then try again by pressing the credit button .
you should see the signals width change.
jizzfu77
7CR
Still the same, no changes when i press the credit button. The game works fine if in test mode (so no credit required) but you will start with all power up and 99 thunder.
NOTE: the opto pin 16 is connected to pin4 on the ic135 (74ls257), maybe i can try to check/change this one.
