Yoke readings(how to take them)
stevebm1
36 (100%)
1,166CR
Ive just been gifted a couple of old samsung 20” crt tv’s,which im hoping to rob the tubes from to use in a couple of my cabs,it’s been quite a few years since I last did a tube swap so can someone please remind me how to take the yoke readings with a multimeter please,
Ace`
PlanB contributor #1
38 (100%)
3,865CR
Disconnect the yoke from the chassis and measure each pair with a multi meter in ohms and note the readings. There's also different neck types to take into consideration.
I used to have good luck with Samsung tvs/tubes having the correct yoke / neck. Not so sure about the Thomson, plus it might not fit in a frame as it's 20" and not 19".
stevebm1
36 (100%)
1,166CR
Ok the tubes have the following yoke readings
AE51EBV13X01
Vertical 14.9 ohm
Horizontal 3.7 ohm
A48ECR11X61
Vertical 13.5 ohm
Horizontal 2.2 ohm
So any good for hanty chassis?
Ace`
38 (100%)
3,865CR
The Samsung one looks good as suspected the other the horizontal is a bit high but might work. It's been forever since I messed with this stuff but high reading either means the image might be too small or too wide. Some times it's close enough and you can adjust the width coil to get it where you need it.
stevebm1
36 (100%)
1,166CR
Thanks for the reply,it is appreciated,good to know that at least 1 is probably useable,perhaps I need to check with TB2000 on the other one,just to be sure,as I know he often uses donor tubes
stevebm1
36 (100%)
1,166CR
Ok samsung tube is now in a spare frame,jusr gotta change some plug types to connect the yoke,degauss,and earth wires
