The above is Ubuntu 11.04 and the Linux port of the menu.
I patched the ZVG drivers so that vector writes are (optionally) mirrored to the screen as well as the ZVG. You can have both displays running in tandem, or if the ZVG isn't detected it'll output to the PC only.
Should make life easier, previously I had to have the cab next to the PC, turning the vector monitor off during code updates so it doesn't sit on the spot killer, then powering up to test the results of new code. I was getting a little worried that all the power cycling would lead to ill health of the monitor. Now I can get things working by the output on the PC monitor alone (and in colour, as I only have a G05 to hand!), then connect to the cab when all looks good and I should see the same thing.
Next up is an attract mode tweak... 30 secs or so of random games during screensaver mode
I've got an XP VM on the same box so I can compile the DOS version too - I never did get cross compiling working properly so now at least I can do it all from one box without reboots into different OS's.
